extra wire under rear seat
Old 04-26-2009, 09:13 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
was cleaning under the rear seat, and saw this wire. whats it for?
Attached Thumbnails extra wire under rear seat-img_0691.jpg   extra wire under rear seat-img_0692.jpg
Old 04-26-2009, 09:18 PM
gblass's Avatar
Possibly for heated rear seats?
It's just a guess.
Old 04-26-2009, 09:22 PM
turboawd's Avatar
It's just a guess.
no, those were already connected. there is one at each end of the seat.
Old 04-26-2009, 09:34 PM
turboawd's Avatar
rear seat removal instructions:
yank up on the front edge of the seat. there are 2 clips holding it down.
after you lift the front a little bit, slide the seat forward a little. then you can lift it up. if you have rear seat heaters, you must disconnect those wires before you can lift the seat up all the way.
to put the seat back in, align the seat belt buckles with the holes in the seat, slide the seat bottom underneath the seat back. then push down on the front edge of the seat to snap the clips back in place.
Old 04-27-2009, 04:56 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
The wire is most likely the one for the battery switch that is only used when the car is being transported from the factory to the dealer...
http://forums.e60.net/index.php?showtopic=9299
Old 04-27-2009, 05:57 AM
turboawd's Avatar
wow, never would of thought of that.
and my wire was sticking out from under the seat also, like others had said.
socale39
09-05-2023 08:30 AM
rteone
04-07-2015 11:48 AM
ranger530i
03-07-2015 05:49 PM
08-12-2003 11:41 AM
06-17-2003 09:38 PM
Quick Reply: extra wire under rear seat
