Explanation of the tire measurements
For example the explanation for tire size 225/50 R17 94V is:
* 225 means the tires breadth in millimetres (225 mm = about 8.9 inches)
* 50 stands for the tires aspect ratio height to width (the tires height is 50 % of the tires
cross-section breadth)
* R means Radial
* 17 is the tires diameter in inches
* 94 tells about the maximum weight that a tire can accommodate vertically at a given PSI.
For example, the load index 94 means a 1477 pound (or 670 kg) carriage holding.
The bigger the measure is the larger the carrying capacity is.
* V stands for the speed rate, V means constant speeds up to 150 miles/hour
Q = up to 160 km/h = 100 mph
S = 180 km/h = 112 mph
T = 190 km/h = 118 mph
H = 210 km/h = 130 mph
V = 240 km/h = 150 mph
W = 270 km/h = 168 mph
Y = 300 km/h = 186 mph
1 km/h = 0.6214 mph
100 mm = 3.937 inches
If somebody could give the correct offsets for E60?s 16 to 20 inch wheels this post could be added to FAQ?s.
* R means Radial
1 km/h = 0.6214 mph
Z is also combined with W & Y. As Z really means in excess of 149 mph and the W/Y says by how much...
e.g. 245/40ZR18 94Y (186mph)
CertifiedOfficial
05-21-2015 12:42 AM
