exhaust whistle at higher RPM
My Ride: 05' 545i
so I have this Borla exhaust and it seems to whistle at higher RPMs. I checked for a hole but no leaks in the exhaust.
Here is clip from the outside..you can hear a slight crackle at the top range..
not bad until your are in the cabin - you can hear it over the music @ 25sec in and when I hit 4k rpm
another cabin clip..longer video, only applicable part is @ 20 sec so you don't have to go through the whole thing
Anyone have any thoughts or is it time to get a new exhaust?
Engine: N54
Sounds more like an intake whistle to me. Got anything aftermarket for the intake?
My Ride: 05' 545i
negative ghostrider, stock intake box with k/n --- carbon filter delete, but these were the first "mods" I did on the car, before the exhaust. Never had this sound then. I was thinking maybe a cracked intake manifold but engine is fine (no misses, hesitation or stall) coolant is fine as well, the sound really comes from the exhaust and not from front or center of car either.
