Exhaust pipe squeezed and bent - Should I be worried?
Old Jul 21, 2013 | 02:37 AM
kskane's Avatar
My Ride: E60 M54
Model Year: 525i 2004
Default Exhaust pipe squeezed and bent - Should I be worried?
Hi Guys, this is a general question towards the BMW experts here who know more about metal than I do. I was following BMW torque spec to fix the exhaust bracket from the transmission on my E60 M54B25 AT. I have attached the picture but it is not clear. Anyway, this bracket that goes around the two exhaust pipes has a bolt in the middle and is suppose to be torqued to 21Nm. As I was putting it back, the damm torque wrench kept going on with every quater turn I heard a crack noise. After a few good turns, I started thinking why the torque wrench is not clicking and thought to try the bolt next to it that I just tightened to 21Nm and it clicked. So, instead of continuing, I examined the bolt and the strap and much to my surprise, one of the exhaust pipe is starting to get squeezed/bent at the bracket. The round section in the picture is where the pipe is bent/squeezed and the pointer is the bracket edge that is squeezing the pipe.
So, I left the bolt as is. My questions are,
  1. Did I cause damage to the exchaust pipe
  2. Should I have undone the bolt a little?
  3. Will the exhaust needs replacement due to me following the BMW torque spec like a bible?
Thanks in advance and I hope nothing has gone drastically wrong here.
Attached Thumbnails Exhaust pipe squeezed and bent - Should I be worried?-img_20130721_132612.jpg
Old Jul 21, 2013 | 03:51 AM
528canyonrot's Avatar
My Ride: 04 545i6 Mystic Metallic Blue
Your fine. I cant see the picture very well, but sounds like your saying the pipe has a dent in it or you put it slightly out of round. Perfectly OK.
Old Jul 21, 2013 | 04:26 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
i wouldn't worry about that for a second.
tundra
Nov 10, 2016 06:55 AM
PelicanParts.com
Jul 23, 2015 12:50 PM
jinsta
Jul 22, 2015 08:29 AM
olega_ts
Jul 20, 2015 01:26 PM
gray545i
Jul 6, 2015 03:54 PM
