Excessive vibration on freeway
My Ride: 12 VW Passat TDI
11 Subaru STi Sedan (GONE)
09 E60 XI
06 E46 M3 (GONE)
05 Subaru LGT (GONE)
00 Ford Lightning (GONE)
I recently had front bushings replaced since there were cracks which caused vibrations.
I also had springs changed with H&R springs with 19" wheels and tires.
Alignment was performed to factory spec.
It has been about a week since I picked up my car and the vibration on steering wheel is starting to come back.
What do you think is causing this?
09 E60 XI
06 E46 M3 (GONE)
i dont think its tires because it was there before i put my tires...
My Ride: 2021 BMW 540i XDrive Bluestone Metallic on Ivory White Napa Leather. Packages: Executive, M Sport, Parking Assistance, Luxury Seating, Shadowline. Options: M Sport Brakes with Blue Calipers, Body Color Rocker Panel Blades and Spoiler, Heated Steering
Model Year: 2021
How old is your car and how many miles? Check your wheels for bends. Check wheel bearings. For me, I noticed at higher speed it would vibrate excessively. Thought the wheel was bent because that's usually what causes the vibration. Mechanic took the wheel off and said you wheel bearings are shot. 43k miles on the car.
Thats funny. I have the same problem after replacing the front arm bushing and shocks (at the same time)
I'm still not sure what the issue is. Vibration occurs around 60 to 70mph
My guess is that somehow the rim does not fit perfectly around the spacer all of a sudden (aftermarker rims) but my winter tires (original BMW rims) also have the vibration, just slightly less.
I doubt that the bearings are shot all of a sudden. You would deff hear that.
If rotors are warped, vibration should only be happening when braking.
09 E60 XI
06 E46 M3 (GONE)
DId you figure out what was causing this?
I dbout its from the wheels
