ET calculations
Old 05-13-2010, 01:04 PM
tooltec's Avatar
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
As regards the rear alloy,your figure of 11.35mm applies to the outer EDGE of the WHEEL,not the outer edge of the tyre.Consider 3 wheel widths for example,8.5",9" and 9.5",all with the same offset.With the same width tyre on each,the tyre position will be the same on the car for all three wheels.The wider the wheel,the more vertical the tyre walls.In your case,if the new tyre is 10mm wider than the original,the outer edge of the tyre will be 10mm outwards (5mm offset difference + 1/2x10mm).
Old 05-13-2010, 01:24 PM
tooltec's Avatar
Originally Posted by greycoopers
Yup...the rear has 5mm diference...
...I understand that the e60 needs ET15 to ET25 to fit right..
With 172M wheels (8.5" front,9.5" rear) the offsets are 18mm and 32mm respectively.
Old 05-14-2010, 08:27 AM
Ricracing's Avatar
Originally Posted by TakmaN
I always use this for offset calculations. Don't forget changes in inner clearance as well!
http://www.1010tires.com/WheelOffsetCalculator.asp
Great link, thank you TakmaN
My calculations where right
Wheels out front 8 mm and rear 11 mm (inward 1 mm)
+ the tires outwards and inwards.
Thanks also to tooltec
I will order Michelin PS2's (no-RF's) with "rim protection" tires in the size of F 245/40 and R 285/35.
So you are right about that the tyres will come out a bit from the wheel.
I'm sure they will fit in the fenders without rubbing.
Better looks without spacers.
But I guess 5 to 8 mm longer bolts are needed.
The one's for a F07 (5-series GT).
Note that the new F10 will have "higher tires" and also that
the ET's are very different compared to the E60.
So new wheels is a must, when you guys change to a F10. :thumbsdown:
OldSpool87
07-26-2015 02:23 AM
BurtonSnol3order
07-03-2015 09:28 PM
znod
50
01-16-2006 07:06 AM
yvesj
10
09-11-2005 04:50 AM
n m
09-25-2004 03:59 PM
Quick Reply: ET calculations
