Error code
Old Apr 24, 2010 | 08:34 AM
bad_bmw3's Avatar
Hey guys I have a increase emissions screen and a P0174 code (autozone) it has a few different things it could be on the print out they gave me.. My car kinda shakes a little I feel too. What's do all think? Could gas cause it? I went to a mom n pop gas station on the way home a few days ago and everything was fine b4 then.
Old Apr 24, 2010 | 08:45 AM
5FOUR5's Avatar
p0174 pertains to an airleak somwhere after the air mass sensor. Your car shaking would be one of the symptoms. You can start the diagnosis by cleaning your mass airflow sensor, and see if that improves the situation. You didn't mention which engine you have , but aging airboots are a common cause on the i6 engines. If you are taking apart that settion, it would also help if you took out the idle control valve and cleaned it up.
Old Apr 24, 2010 | 09:11 AM
e6t.lab.rat's Avatar
It might help if we know what engine you got.
P0174 per my codekey (fault reader), it says "System too lean Bank 2" Hope this helps.
Old Apr 24, 2010 | 09:14 AM
bad_bmw3's Avatar
Oh my fault I have a 04 530 it a i6 like u said, thanks for the info I'll check those out.
Old Apr 24, 2010 | 12:12 PM
bad_bmw3's Avatar
I've worked on my car quite a bit, but those parts I've never had to change, any idea where those are located?
Randmaster
Apr 2, 2019 07:58 AM
jo786
Apr 28, 2015 02:30 PM
Stranger12
Apr 5, 2015 10:42 AM
wrx5
Mar 29, 2015 04:53 PM
