ERROR 98DF
Hi
I changed my seats from cloth to leather ages ago and it set off my airbag light. Ive ran inpa and the error comes up:
98DF Resistor detonation pill detonation circuit3(Seat belt tensioner right) to small. Error clears until you restart!!
Can anybody provide any input on what this means??
Any help appreciated.
Did you disconnect the battery when you removed the seats? If you remove the seats and the battery is connected, with ignition on, it will set an srs fault. Also check the seat belt tensioner and make sure that the connector is plugged in. the tensioner should be the actual locking mechanism that the seat belt locks into. You'll see the connector if you look between the seat and center console.
Although the error is stating the seat belt tensioner(in red), when i disconnect it with ignition on, it shows error "srs fault, drive carefully"(in amber). That makes me think im looking in the wrong place!!
Ive also tried seat pad control unit and tensioner from my old seat, which i know were fine...................... Totally baffled to find a result!!!
alienintelligence
09-07-2015 12:09 AM
umnitza
09-02-2015 11:28 AM
