Engine won't start 2007 LCI 535d
My Ride: 2007 e60 LCI 535d msport
Hello, people. Looking for help as I am desperate! Bought car from the virtual auction, when it was delivered find out that all pricy modules were removed, including ecu. Bought all of them second hand by the part numbers I needed. Got them programmed by good experienced ectrician, but car would not start. Don't know if it wasn't coded well or something else is wrong with it. Had to replace starter motor as it was burnt, but still no luck. The ignition comes on, when press strat button it turns over the engine, but wouldn't catch on and start. 😱 there is enough fuel, enough oil, chain is not cut, can here fuel pump working when turn on ignition. Any ideas? Thanks in advance!
The key was accepted even before the ecu was recoded. It does lock and unlock the car, turns ignition on. Also the power to starter motor comes and lets you to try starting car, you can hear engine turning over, just gives up after a minute.
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
sanjsanj is right your CAS and DDE need to be aligned. If it is not aligned all you will get is the engine trying to start. I know this is because something similar happen to me and I had to reprogram. They must match and be aligned.
Awest91
09-17-2022 11:05 PM
