Engine suddenly idling erratcally
My Ride: 2006 550i, 6 speed manual
Hi All,
Filled my 550i with Hess premium on Friday night. Started the car this am and it is idling very rough and the idle is bouncing between 1500 and 2500 rpm. No dash warning or malfunction of any kind is being displayed. I'm thinking perhaps a bad batch of fuel. Anyone else have any thoughts/ideas?
Thanks, Ed
Thanks, Ed
Thanks, will probably purchase a fuel additive, dry gas or BG44k if I can find it. It's too much of a coincidence that the problem started right after I filled the tank.
My Ride: 545i
Engine: N62
Could def. be bad gas. I would run a fuel additive and fill up with fresh fuel. Finish out the tank and see what happens afterwards. Are you using Top-Tier Fuel? What station do you normally go to?
UltimatePeter
DIY: Do It Yourself
May 12, 2015 08:00 AM
