"Engine oil at minimum level" in just 3 weeks.
My Ride: 2006 530xi, June 2005 build / July 2005 delivery, Steptronic, premium, premium sound, cold weather pkg, PDC, fold down rear seats, heated rear seats, navigation pro, rear electric sunshade, rear side impact airbags. CIP 20.01 with replaced CCC, lamp control module, oil level sensor
Originally Posted by rodybmw' post='228005' date='Jan 22 2006, 06:47 PM
It seems more like a faulty level sensor or software issue since the level in iDrive changes after the engince gets to full warm up. At 5 minutes into the drive the oil has already been pumped in all areas of the engine, so the level should not change in another 10 minutes. So it may be the sensor of software. Since there is no dipstick to confirm the oil level I would not keep adding oil if I were in your place (you may overfill the engine if the true problem is the sensor).
My Ride: 2006 525xi
When I got this message the first time at 42k miles, the mechanics actually drained all my engine oil and measured it. It was indeed one quart less at least according to him. I don't know what they are gonna find out this time. I did check my car underneath this time and opened the hood. Everything looked very clean to me. No sign of leakage.
The oil capacity in all cars are different when the oil filter is also replaced vs. when the filter is not replaced. If they just drained the oil and measured the drained amount it would not take into account the amount of oil retained in the filer and filter housing area and all the remenant oil in the oil pan and other areas. I have not changed the oil in my 545 myself, but in most of my other past and present BMW's on which I have done oil services myself the oil capacity without a filter change has usually been almost exactly one quart less than the oil capacily with a filter change. So if I were to change the filter, fill the oil to the proper level, run the engine for a couple of minutes, and then drain and measure the drained oil it would probably also be one quart less than what I filled in it a few minutes before (because of the amount retained in the filer, etc). So I am not sure if draining and measuring the oil is an accurate indication UNLESS they take the oil retained by the filter and elsewhere into account.
My Ride: 2006 525
u have a 2006 model and have 43K miles on it already?!?!??! whoah.
im wondering if the new aluminum/magnesium engines drink more oil than the old engines. my '06 has 8K miles and had to put in a quart at around 5K miles...im now seeing the oil guage slowly creep lower as the weeks go by.
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Cold Weather Package
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
Thats awful strange for a 525xi, did you get under the car and look for oil spills, I gotta tell you, sometimes the old ways are the best..... the good old dipstick, it never lies. A trip to the dealer is wise, make sure they give you an honest answer. Good luck my friend.
[/quote]
You describe the exact normal behavior for the oil level detection system. Upon startup, the reading is inaccurate if it even returns a reading at all. Once the oil circulates and the car warms up, the reading that is returned is the correct one.
My Ride: 2006 525xi
I heard back from my SA today about the PUMA that he filed with BMW. Apparently there is a problem with the oil sensor, so mine will be replaced. The part is on back order and is expected to take a few weeks to arrive. This may or may not be the same as JFiRB's problem, but I figured I'd let you know nonetheless.
My Ride: 2006 525xi
Originally Posted by JFiRB' post='228622' date='Jan 23 2006, 11:01 PM
Thanks for the update. I read your signature and couldn't believe my eyes! I too have a replaced CCC, which broke on my way home from NYC. I too have malfunctional head lamp. I too have CIP 19.02. I too am from MA, and I too have engine oil problem. What a coincidence! What is going on in Massachusetts!
I have been wondering whether these problems are because I have one of the early '06 xi builds (built in June). Is yours a pre- or post-September build?
I also have another unrelated problem that was confirmed by both service centers: the rear suspension emits a fairly loud creaking sound on a really cold day (single digit temperatures) when driving over a bump in the road. It is most noticeable when you first drive off if you leave the car parked outside overnight. BMW has confirmed this as well through another PUMA. I believe it has something do with the the linkage in the suspension, though I'm not sure of the specifics. There's no known fix for it as of yet, but they're supposedly working on one.
