5Series.net - Forums
-   -   Engine oil at minimum level (https://5series.net/forums/e60-discussion-2/engine-oil-minimum-level-135590/)
IceBimmer Oct 22, 2013 12:37 PM
I started getting "Engine oil at minimum level" message at around 70k miles. I have been dealing with this problem by adding one quart of oil at a time. It seems getting worse now. I get the oil low message after just 1,800 miles of oil change at 83k miles. No oil leak was found. What could be the cause of this ? :help:
545iMike Oct 22, 2013 02:52 PM
Is your car smoking at all? Could be valve stem seals and/or guides.
IceBimmer Oct 22, 2013 03:49 PM
Just some white steam in the cold morning.
545iMike Oct 22, 2013 07:15 PM
Nothing after its warmed up? You must have a leak some where.
tonyb635 Oct 23, 2013 02:09 AM
I hate that damn message when it comes on! I know that my E60 and F10 will illuminate if I let it go all the way to the service time. I always change my oil mid point and I have never received this annoying light anymore. Well, that was until the last mid point change. Half way through mine came on but I know I have a slight leak, or what appears to be a slight leak around the oil filter area. Could be more, but you won't know unless you unbutton this beast. These cars are so covered up it's crazy. I think if you had a leak one might not really know it unless they were to remove the lower panels. If one quart in 7000 miles is all that I will lose, I guess I am ok with this. The inspection is on my huge list of things to do, just so I know if there is a leak that needs attention. But I do have to admit that light is scary when it does come on, but in the end it's just one qt.
FormerE30Owner Oct 23, 2013 08:40 AM
Are you saying that you needed to add 1 qt at 1,800 mi after an oil change? Was the proper amount added during the oil change? I always check the level after an oil change.
Even 1800 mi is within the BMW oil consumption spec., albeit on the high side.
There is a good side to oil consumption/loss - making up the oil replenishes the additives and permits longer change intervals!
Salut, Bob P.
IceBimmer Oct 23, 2013 08:43 AM
The technician said the engine vacuum reading is a little off and there is some smoke coming out from the pipe after idling a few minutes. So it could be both the crankcase breather valves and valve stem. I have them changed the breather valves ($166 parts and labor) only. It will cost about $4000 to replace the valve stem ! :mad:
545iMike Oct 23, 2013 02:40 PM
Double check that your valve covers and CCV hoses are not leaking at all. If they are leaking, they can cause excessive oil to be sucked through the CCV into the intake manifold. You can pull one of the CCV hoses off the intake manifold to check for excessive oil. If you have the new style hoses you can determine which bank is leaking. Its a little harder to tell with the old style hoses because they connect together.
SFS550 Oct 24, 2013 11:06 AM
I've been having a similar issue, and thought my 02 sensor had something to do with the white smoke. Obviously I now realize I have a much bigger issue I'm dealing with here. I'm about to hit 110k with no warranty and have no cash to make any repairs at the moment.
Now I'm worried!
ncsugrad2006 Oct 24, 2013 11:09 AM
Where are you located?
There is a BMW tech, I believe in the New Jersey area, that replaces them for $2500 on the weekends. Supposedly does a great job.
