Engine Oil leak
just opened up the hood and noticed engine oil leakage. I had oil/filter change couple of months ago. Took the car to mechanic and he suggested to get the engine stream cleaned so that we can figure out the leak.
I read that its not safe to get it stream cleaned. Looking forward to your suggestions about what to do before I can take it to stealership.
Also, I never saw any oil leaks on the floor where I park. I guess its minor but I need to get it done.
Thanks!
Thanks!
My Ride: BMW
What year and model is your car? Also, why don't you post a pic of where the oil is. I've seen threads here with pictures of oil leaks and some members being able to tell where it could be coming from.
Depending on the age and mileage, could be valve cover gaskets or timing cover or both. I had these replaced at 117k on a 2005 545. Started with noticeable stains on the engine compartment floor and got worse gradually over several months. Never any staining on the driveway though.
If that's the problem it will cost $$$ unless under warranty.
Oil leakage has been the #1 problem in my car: 2004, 545i.
Ive chased it from the upper pan, to lower pan, & now there is another one.
None of this pertains to you directly, but Id suggest finding someone you trust to fix it quickly, as oil leakage over time (if near other seals, rubber components, etc) can diminish them as well.
My Ride: BMW
Bet you''re hoping it's something simple like that. As was previously posted you can use a good degreaser cleaner like purple or green stuff on a cold engine to clean things up a bit. If you are hosing anywhere near the electronics cover them completely with plastic wrap so they don't get wet from overspray. Another technique I've used to track leaks - after the engine is dry "dust" it with some talcum powder. Leaks will show up by leaving a trail in the white powder. And as a side benefit your engine compartment will smell like a baby's bottom
Good luck getting it sorted out.
Now since I just got my engine oil and filter changed, I want to clean up the engine so that we can spot a leak.
I attached some pics above if you can suggest something.
Thanks!
