Engine malfunction/too rich after fixing injectors
My Ride: 325i
My journey first was summarized with this post and has now continued with new symptoms.
Short version:
had misfire at random times
Changed battery
Eventually went to Indy shop
They did Walnut blast and oil filter housing gasket
Short version:
Changed battery
They wanted 3k for injectors (I did them myself and coded)
the misfire is now gone but I get bogging at light throttle and the engine malfunction/too rich codes after a WOT pull.
What now? I'm about 1800 bucks into this and I've just got new issues.
Engine: N54
Check gap and re-torque the plugs
Check plug cable for any arc traces
check plug holes for any oil contamination
what did you use to code for the new injectors?
What part number injectors?
My Ride: 325i
Gaps and torque seem fine
Don't find any ARC traces
Used inpa to code everything. Is there anything other than updating the values that is needed?
I used the injectors https://www.summitracing.com/parts/SMP-FJ1284
Engine: N54
What are the codes you are getting?
Also, think abut doing some logging if you dont have the gear for that yet. MHD app on the phone and a proper cable
My Ride: 325i
What cable so you recommend?
Engine: N54
My Ride: 325i
Engine: N54
My Ride: 325i
I dont have the logging cable for the jb4, but since I already have the dcan cable, I just ordered an OTG adapter and I'll run with MHD. I'll post logs once I get the adapter.
