Engine Malfunction error with Sprint Booster???
My Ride: 2005 545i- Titanium Gray
Ok so I got my Sprint Booster today and with all the help of the forum went to install it which was simple as stated.
When I started the car to test the goods I got the !ENGINE MALFUNCTION-REDUCED POWER error message.
I had heard of faulty units so I took the unit off and reconnected, same message. So I decided to take it off and email Andy Wong to get a replacement, when I went back to stock I get the SAME ERROR MESSAGE???? It wont go away!
Is there a quick fix for this or am I going to have to take this to the dealer like an idiot?
Thanks in advance for the help.
Jake
Jake
From what I've read, you'll need to drive the car for ~ 200 or so miles before it will go away.
Michael
Michael
Jake
Jake
Are you pulling my leg, I haven't read that anywhere?
Jake
Jake
Michael
Michael
No I'm being serious. I forget what thread I read it in but I did.
Michael
Michael
Jake
Jake
Well I have the sb on now and it seems to be working but I have that damn error message and a yellow engine image in front of me!!! This blows....bump up for more feedback.
Jake
Jake
Michael
Michael
My Ride: 2010 VW Passat Wagon 2.0l Tsi
Grey/Grey Budapest 18"
Lost to HPFP issues:
08 535i sport pkg
Lost to Dreaded E61 Sun roof leaks:
07 E61 530Xi
Yep from what other people have said you may have to go to the dealer to get it cleared.
There was batch that some people had issues with. Alot can be traced back to not having the key in the ignition, or with comfort acess , not far enough away from the car. Also got to match the pins up correctly , and get a firm conection.
My Ride: alpinewhite's ride
Take out the SB and drive it for about 50 miles with SB in. The car will reset and the error message will disappear. Install the SB again and make sure the numbers match and the SB is secure fit with the pedal.
Thanks. I sent it back for exchange.
Jake
Jake
Jake
Jake
Maybe just a check on the connector socket to make sure ?
