Engine Malfunction
1 Attachment(s)
I have attached a DTC Report
Basically car started ed misfiring on cylinder 5 Replaced Spark Plugs and Coils RESULT= Still Misfiring Replaced Cam and Crank Sensor Result = Multiple missfire Replaced VANOS Selenoid Result = rough idling and the codes attached on DTC report. All parts were replaced with oem only I have also replaced oil pressure sensor. What I have been reading is that timing jumped a teeth which i found hard to believe since is chain. Can anyone help out thanks |
Fuel injector(s)?
| All times are GMT -8. The time now is 07:08 AM. |
