Engine malfunction
My Ride: 2003 E60 520i Black Metalic. Glass Sun Roof, Climate Control High, Bluetooth, Leather Memory, PDC, Adaptive Xenon, Navi Pro, Voice Control, Ipod, Folding rear seats, OEM 172 19" Summer Wheels, OEM 138 17" Winter Wheels.
OP: A battery should definitely last longer than two years. I am curious how they come up with the 50% number. It is quite hard to "estimate" the remaining service time of a battery...
If your car turns on the check engine light, there has to be a error code stored in the memory. It does not sound right that there are no codes. Maybe you should try another workshop. Are you using a BMW dealership or?
I dont believe that the check engine light is caused by a "bad" battery. If the battery is worn down, you will notice it when you start the car where the engine would crank "slow" or not at all. If it cranks normally and starts with no issues, the battery is fine.
My Ride: E60
Yes, I'm using BMW dealership in Southern California. They kept the car for 2 days and said no code found. But so far the engine light hasn't' come on again. I'll try another dealer, if the light came on again.
You can get a cable including CDs with the needed SW from EBay for approx 150 USD. Then you can read out the errors yourself. Much better than relying on somebody else :-)
Here is one
BMW Progman V41 USB OBD Package Dis SSS Ncsexpert Inpa Ediabas | eBay
There are others that are cheaper, but I am not familiar with them. I bought the package above. It allows you to read out errors, reset battery etc etc. You can even do coding.
Awest91
09-17-2022 11:05 PM
