Engine issue - Will not start
Hey, got a 2004 mod E60 520i.. Been pretty good car the months I've had it, until today.. when I went out to start it the engine would not start. I am sure it is not the mpm, considering I had issues with it not too long ago and fixed that. Lights, meters and the idrive screen all works as intended, but the engine doesn't make a sound, it's not even trying to start.
Now I am just making this thread to see if anyone knows what the problem is by my badly written explanation, cheers![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
- Jannick
- Jannick
One of the following is likely the culprit, you will need to go thru each one of them and find the root cause -
Battery, starter relay, starter, fuel pump, ...
If the battery is original one, battery may be on it's way out. Recharge the battery and see if the battery is holding the charge; test the battery voltage. Once you rule that out (or you know for sure, the battery is good), then you will need to look at starter relay and starter.
If I have to guess, I'd guess the starter and/or the battery.
