engine difference 545i vs 550??
My Ride: 545i 2004, SMG, Sport, Nav, Logic-7, Bluetooth phone retrofit
They fixed most of the sealing problems. They also put a big oil cooler on it, which supposedly helps the sealing problems too. The 545 was known to run high oil temperatures, which is hard on the seals.
My Ride: 2006 550i
Auto trans, Navigation, Comfort Access, Adaptive Lighting, Dynamic Drive, Sport Package, Logic 7 Audio, Voice Control, Shades, Active Steering, PDC, Heads Up Display, Heated Front Seats, CD changer, Satellite, Extended Lighting Pkg
HOWEVER!, Be warned that the 550 engine is still likely to developed the valve seal problem , which is QUITE expensive to fix. IF you have a choice, skip over the v8 and get the 535i with its turbo. I love the power of my 2006 550i, but I have both a valve cover leak (haveing to add a quart every two weeks) plus the white smoke when idling, that comes from the valve seals leaking. I discovered the valve seal problem about a week after my purchase with no warranty!
