Engine cranks however doesn't start
Its a 525i 2007 n52 e60
The battery had drained and it was jump started without any issues the first time. However, a month later, it didn't start when I tried jump starting it. The car cranks, engine turns, yet does not start. The battery is good. Fuses in the glove box and the trunk are good. The spark plugs aren't getting any power(Voltage). Not sure what to look at next: Any Relays to check? Any way to check the dme? what else to check?
The obd2 reader was connected for codes however its output was "U110F The DTC definition is not availiable"
Help Please! Thanks in advance
thesalboy
Apr 8, 2015 09:13 AM
