5Series.net - Forums
-   -   Engine coolant service , plz help.. (https://5series.net/forums/e60-discussion-2/engine-coolant-service-plz-help-104531/)
afzalk72 Sep 26, 2010 05:34 PM
Hello Every one !
I have 2006 525 xi with 81 k miles, for a preventive maintenance reason can any one advice me regarding engine coolant flush, my dealer told me its a life time coolant and there is no need to flush if there is no issues however I called several other dealers and they told I should replace it every 2 years, I called BMW north America and the rep told me that he doesn't see any where to flush the coolant on 2006 e60's. So I don't know who to believe :confused: . Please advice if I should pay $140 for flushing, car has no issues.
Thanks...
kane1111 Sep 26, 2010 05:59 PM
If it aint broke DON'T fix it!!!! :nono:
salaki Sep 27, 2010 08:18 AM
Flush it.
Radiator coolant should be replaced around 60-75K if you want to keep your car last longer.
Oh while flushing, do water pump and thermostat too as preventative maintenance.
You'll be sorry if these two break in the future.
Diamond Sep 27, 2010 02:59 PM
Originally Posted by salaki (Post 1244642)
Flush it.
more poor advice. In the n52 with electric water pump, you do NOT want to change that until it is broken. They do not have typical "wear" pieces such as spun bearings or tension strain from the belt--since it is not belt driven and the same bearings dont exist. That was the only reason to prohlitically change a pump before. With the electric pump there is not telling one that will go for 20k or one that will go for 120k miles. Many are changed only to break again. If you have one that is working strong at 75k I would not think of touching it.
The flush should be done. I had mine done at 30k and then again at 50k--had 2 repairs that required this but I will continue every 25k miles.
afzalk72 Sep 27, 2010 04:36 PM
Today I checked the coolant reserve tank and it shows the regular water no blue or green color water, is it normal or better off spend $$ and have flushed. Thanks guys !!
Diamond Sep 27, 2010 06:10 PM
ya its not supposed to be clear. SOmeone dumped way too much water in your tank.
Also you cannot open your resevoir and close it without doing a bleed of the coolant system
afzalk72 Sep 27, 2010 06:45 PM
I did open and close the reservior and then drove my vehicle, dont know how to bleed :unsure: will driving without bleed until I go for a service will damage the cooling system?
vsark Oct 10, 2010 04:54 PM
Is there a DIY for coolant flush?
kreveta Oct 11, 2010 12:07 AM
My dealership claims it's good to flush it like every 5 years or so.
Diamond Oct 11, 2010 02:50 AM
Technically protocol is it is a lifetime flush which to bmw means 100k miles. That is their lifetime. Includes tranny flush as well and spark plugs all get rec. to change at 100.
I had my cylinder head replaced at 40k and my radiator replaced at 52k so I have had my coolant flushed and changed twice. I will probably do it every 3 years at this point unless something breaks.
Honestly odds of something NOT cuasuing you to need to flush coolant in 60k miles is probalby rare-something will go and will end up having to.
You wont destroy your engine but if you dont properly bleed your coolant lines after you open your system to the atmosphere, you will get air pockets that build in your system, including the engine coolant passageways and then uneven distribution of coolant due to the pressure differentials.
If you need to check and add coolant, to bleed, all you have to do is leave the cap off the resevoir after you fill it up.
Start the car with the defrost button on (fan can be on low)-this ensures the coolant is passed and ran through the heater core and completes the circuit. Leave the engine running until the car is up to full temperature. The coolant is not fully pumped through the whole system until the block is up to temp. Lightly rev the engine multiple times throughout the 10 minutes or so it will take on a normal temp day. Then while car is still running cap the tank and you are good to go
