Engine coolant service , plz help..
Hello Every one !
I have 2006 525 xi with 81 k miles, for a preventive maintenance reason can any one advice me regarding engine coolant flush, my dealer told me its a life time coolant and there is no need to flush if there is no issues however I called several other dealers and they told I should replace it every 2 years, I called BMW north America and the rep told me that he doesn't see any where to flush the coolant on 2006 e60's. So I don't know who to believe
. Please advice if I should pay $140 for flushing, car has no issues.
Thanks...
. Please advice if I should pay $140 for flushing, car has no issues.Thanks...
Flush it.
Radiator coolant should be replaced around 60-75K if you want to keep your car last longer.
Oh while flushing, do water pump and thermostat too as preventative maintenance.
You'll be sorry if these two break in the future.
The flush should be done. I had mine done at 30k and then again at 50k--had 2 repairs that required this but I will continue every 25k miles.
My Ride: 2004 530i, Silver Gray, Premium Pkg, Cold Weather package, Black Leather seats with lumbar support, Poplar wood finish.
Mods: M6 19" wheels with 245/35/19 Front Tires 275/30/19 Rear Tires, K&N Filter, H&R Sway bars, Magnaflow Muffler, Sprint Booster, Black front grill, M-tech front bumper, Debadged
Is there a DIY for coolant flush?
Technically protocol is it is a lifetime flush which to bmw means 100k miles. That is their lifetime. Includes tranny flush as well and spark plugs all get rec. to change at 100.
I had my cylinder head replaced at 40k and my radiator replaced at 52k so I have had my coolant flushed and changed twice. I will probably do it every 3 years at this point unless something breaks.
Honestly odds of something NOT cuasuing you to need to flush coolant in 60k miles is probalby rare-something will go and will end up having to.
You wont destroy your engine but if you dont properly bleed your coolant lines after you open your system to the atmosphere, you will get air pockets that build in your system, including the engine coolant passageways and then uneven distribution of coolant due to the pressure differentials.
If you need to check and add coolant, to bleed, all you have to do is leave the cap off the resevoir after you fill it up.
Start the car with the defrost button on (fan can be on low)-this ensures the coolant is passed and ran through the heater core and completes the circuit. Leave the engine running until the car is up to full temperature. The coolant is not fully pumped through the whole system until the block is up to temp. Lightly rev the engine multiple times throughout the 10 minutes or so it will take on a normal temp day. Then while car is still running cap the tank and you are good to go
will driving without bleed until I go for a service will damage the cooling system?
