EGR problem?
Old Oct 20, 2009 | 01:32 PM
BMWWW's Avatar
Hi you all!
After reading some of the topics regarding EGR and intake manifold, my eyes are tyred and still confused.
These days I've cleaned up the EGR valve from my 03.2004 530d.(just for prevention, no errors, no engine problems)
Not surprised to find lot of dirt in there, but surprised to see that the valve didn't move at all first, and started to move very hard after cleaning.So i guess untill now my EGR didn't work?(no faults on the dash).After cleaning, the engine is running the same way like before, no difference.Questions:
1.How can i find out if it's working now?(except replacing it, and observe if any difference).
2.Can i gain some power or a better response of the car by having the EGR working,or doi have these things when it's not working?
Thank you.
Old Oct 20, 2009 | 01:56 PM
BMWWW's Avatar
Nobody here who can help?
Old Oct 21, 2009 | 02:35 AM
BMWWW's Avatar
Originally Posted by BMWWW' post='1036894' date='Oct 20 2009, 04:32 PM
Hi you all!
Thank you.
Sttill no sugestions.... nobody....???
Old Oct 21, 2009 | 05:38 AM
porsche911targa's Avatar
Might not be a common problem.
Old Oct 21, 2009 | 12:14 PM
Anzafin's Avatar
My Ride: Bmw 530d 2004
Originally Posted by BMWWW' post='1036894' date='Oct 21 2009, 12:32 AM
Hi you all!
Thank you.
1) Maybe through OBD2 port...?
2) I don't think either way will give any more power. But sure a cleaner engine when it's shut.
- Antti -
Old Oct 22, 2009 | 04:05 AM
tuningteknik's Avatar
Hi,
EGR valve is only for emmision. If it's stock you will get a higher fuel consumption.
Old Oct 22, 2009 | 04:15 AM
steve.r's Avatar
I have a suspected EGR problem with my 2006 525d, which is still under warranty. BMW UK have advised my local dealer to remove the vacuum hose temporarily (24hrs) to see if the running problems still exist.
My economy hasn't really been affected but the engine management light has come up showing an error with emissions which is to be expected, I believe.
I didn't remove the pipe, but only took a couple of minutes to do. Apprently if the car runs better without this pipe this would start to point towards an EGR issue....worth asking your garage?
Old Oct 22, 2009 | 05:46 AM
BMWWW's Avatar
- Antti -
thank you.
bbbamboo
Sep 17, 2017 04:33 PM
BEZ101
Apr 15, 2015 11:43 AM
BEZ101
Apr 14, 2015 12:40 PM
thesalboy
Apr 8, 2015 09:13 AM
BEZ101
Mar 10, 2015 06:22 AM
