e60 Used Advice
Been looking for awhile for an E60 - 2006 530i. Came across one. When I checked the history, it showed a whole bunch of maintenance work being done on it. Should I be concerned? Should I stay away? advice please.
Figures on the left is mileage when the maintenance work was done.
4XXXX - leak oil pan, auto tranny leak
4XXXX - fuel tank leak, sunroof leak?
6XXXX - radiator leak
6XXXX - ticking noise, full flow filter body leak
7XXXX - coolant temp sensor leak
7XXXX - coil fail
Current mileage about 74k
Thanks appreciate the help.
7XXXX - coil fail
True.. everyone's a stranger. Its a private sale. I could seriously use some help though. Its one thing to hear from an owner that the car is in pristine condition, and when you see it, you all but realize that he/she has a different definition of pristine.
...but if you're the owner of that car and trying to sell me your car.. you suck
Anyway, as the info to the left indicates, I'm new to this site. Is there a Private Messaging system where you could tell me about the car without cluttering the thread? I could drive by and take a look at the vehicle, what the hell. Save you 14 hours on a bus if it's a complete POS.
