E60 Suspension
Old Sep 15, 2014 | 06:56 PM
Germancars007's Avatar
My Ride: 2004 545i 6 speed
Default E60 Suspension
I have a 2004 545i with 67k miles. i feel like the car is lower than it should be because the shocks are wore out. Do you guys recommend getting an aftermarket set up or buy the OEM shocks? I wouldnt mind my ride being a little lower but i just dont want my ride to be to rough.
Old Sep 15, 2014 | 07:53 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
shocks/struts dont lift the car. they only dampen movement. worn shocks done lower the car. worn shocks result in a more bouncy ride.
springs are what hold the car up. shocks just control how they bounce.
Old Sep 15, 2014 | 08:17 PM
can i get springs that lower my car by about 2 in. and keep the same shocks?
Old Sep 16, 2014 | 12:01 AM
jonnyenglish's Avatar
My Ride: looking at 550i
Yes you can, however you've mentioned that your struts are worn out. Replacing the springs on worn out struts is a very bad idea. Best option is a spring and strut combo/coil over system.
Kasmo
Jun 27, 2024 06:02 AM
Nihilation
Jul 10, 2022 11:32 AM
ArnottInc
Apr 2, 2015 10:46 AM
ZeZe
Oct 15, 2003 12:58 PM
