E60 start problem / rough idling
Old Mar 16, 2015 | 03:33 PM
Stranger12's Avatar
My Ride: 530d
Default E60 start problem / rough idling
Hi all,
As some of you may have seen my earlier posts , I am having a nightmare with my e60 and the problems are as follow:
1.Rough idle on cold and warm and the car shakes as if there is an earth quake
2. doesn't start up, it cranks over but no start and shows three errors which are transmission fault, fuel pump fault and dsc fault
3. yesterday not only it did not start it stopped cranking over while the battery was ok and it did start after 10 mins or so
so far
1. I have changed the DDE relay ( blue relay in ecu box) .
2. I have used wd40 on all relay pins and female connectors plus the ecu wiring ( took it off , sprayed it on it and waited from around 1 hour before plugging it back in).
3.changed the boot relay ( black one ) not sure what it is called.
4.changed battery from 90 ah to 110ah .
now I am short of ideas as the problem is getting worse yet I am nowhere.
Here is what I have found from hours of online search :
1. Could be dde relay (sky blue) as if that is not working no signal is sent to gearbox and fuel pump.
2. could be the glow plug . My glow plug number 5 is gone and was gone from Sept 2013 . didn't have any issues with it until last 2-3 month .
I have read people saying the glow plug could be taking too much power or current hence throwing all kind of errors as the volt is dropping below x volt .
Can glow plug play a role in idling a car?
3. could be the fuel relay rail wiring . I have checked it and all looks good. it was suggested that the wiring if loose can cut fuel supply and cause rough idle etc .
I have taken the cable out and can see the car suddenly shakes but then all goes back to normal and start to work again
4.could be battery or alternator . battery change , alternator not sure if I should do it .
5.could be ibs sensor . I have no clue where it is and what it is .
6.could be fuel filter if clogged. I have just changed it less than 1k ago when the car still had the issue and still has it .
7. could be egs blocked, could it be ?
and the list goes on . I don't want to spend few £ ks with stealer to fix thus I am doing all i can to fix it .
what I am doing next :
1. take the manifold apart and clean it
2. take the ecg out and clean it .
3. change number 5 glow plug.
Please help if you can and below is the latest inpa log from the machine
You can see couple of voltage drops to below 10v which I am not sure what that would be .
also does anyone know which ecu should I check for egs errors as it is not in dde yet in INPA inside functional jobs section I can see code 5150 for egs
Also what is the difference between logistic counter and error counter
ECU :
E R R O R M E M O R Y
Date: 16.03.2015 21:16:16
ECU: D50M57C0
JobStatus: OKAY
Variant: D50M57C0
RESULT: 13 error in error memory !
3F40 3F40 (3000) commen rail sensor Offset-Test
Error counter: 18
Logistic counter: 37
1. Umweltsatz
Mileage 221848 km
mean engine speed 0.00 rpm
coolant temperature 81.25 deg C
max rail pressure of the recent 10ms 102.40 bar
injection mass index value without mass balance control 0.00 mg/cyc
intaken air mass per cylinder 0.00 mg/Hub
value of boost pressure 1014.15 hPa
raw value of rail pressure 736.25 mV
Battery Voltage 13197.03 mV
Vehicle speed 0.00 km/h
fuel temperature 34.06 deg C
2. Umweltsatz
Mileage 222592 km
coolant temperature 85.26 deg C
max rail pressure of the recent 10ms 110.28 bar
value of boost pressure 1004.30 hPa
Battery Voltage 12708.25 mV V
fuel temperature 33.06 deg C
Offset Maximum ueberschritten
Test conditions not yet fulfilled
Error not present now, but already stored
Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase
Error code: 3F 40 31 06 00 00 12 25 6C 53 00 83 0D 00 00 67 22 51 00 54 6C B0 00 87 0E 00 00 66 22 4E 00 53
4536 4536 Powermanagement Battery
Error counter: 154
Logistic counter: 40
1. Umweltsatz
Mileage 221888 km
coolant temperature 9.97 deg C
max rail pressure of the recent 10ms 55.14 bar
value of boost pressure 1023.99 hPa
linearised APP1 0.00 %
Battery Voltage 9286.80 mV
atmosphaere pressure 1014.15 hPa
2. Umweltsatz
Mileage 223208 km
coolant temperature 24.02 deg C
max rail pressure of the recent 10ms 204.81 bar
Battery Voltage 12219.47 mV
Tiefentladung Test conditions fulfilled
Error present now and already stored
Error code: 45 36 62 06 00 00 9A 28 6C 58 00 3C 07 00 00 68 00 39 00 67 6C FD 00 4A 1A 00 00 68 00 4B 00 67-------------------------------------------------------------
4661 4661 Supply voltage
Error counter: 2
1. Umweltsatz
Mileage 221888 km
Battery Voltage 6842.90 mV
2. Umweltsatz Mileage 221888 km
Versorgungsspannung DDE unterschritten
Test conditions fulfilled Error not occurred yet
Error code: 46 61 02 06 00 00 02 25 6C 58 00 3C 07 00 00 68 00 2A 00 67 6C 58 00 3C 07 00 00 68 00 2A 00 67-------------------------------------------------------------
44E2 44E2 Generator
Error counter: 1
Mileage 222368 km
mean engine speed 634.40 rpm
coolant temperature 60.16 deg C
max rail pressure of the recent 10ms 322.96 bar
injection mass index value without mass balance control 13.78 mg/cyc
intaken air mass per cylinder 466.32 mg/Hub
Battery Voltage 11893.62 mV
atmosphaere pressure 1023.99 hPa
keine Kommunikation ueber BSD-Schnittstelle
Test conditions not yet fulfilled Error not occurred yet
Error code: 44 E2 14 02 00 00 01 25 6C 94 17 6E 29 23 4A 68 00 49 00 68
4C13 4C13 data (STAT_DSC, 0x19E)
Error counter: 1
Mileage 222368 km
mean engine speed 661.98 rpm
coolant temperature 58.16 deg C
max rail pressure of the recent 10ms 315.08 bar
injection mass index value without mass balance control 10.63 mg/cyc
intaken air mass per cylinder 478.92 mg/Hub
value of boost pressure 1053.53 hPa
Battery Voltage 14337.51 mV
Botschaft von DSC ausgefallen
Test conditions not yet fulfilled Error not occurred yet Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase
Error code: 4C 13 18 02 00 00 01 25 6C 94 18 6C 28 1B 4C 6B 00 58 00 68
4C23 4C23 data (TORQUE_DSC, 0xB6)
Error counter: 1
Mileage 222368 km
Botschaft von DSC ausgefallen Test conditions not yet fulfilled
Error code: 4C 23 18 02 00 00 01 25 6C 94 18 6C 28 1B 4C 6B 00 58 00 68
4C28 4C28 data (VELOCITY, 0x1A0)
Error counter: 1
Mileage 222368 km
Error code: 4C 28 18 02 00 00 01 25 6C 94 18 6C 28 1B 4C 6B 00 58 00 68
4BE3 4BE3 data (GEARBX_DATA, 0xBA)
Error counter: 1
Mileage 222368 km
Botschaft von EGS ausgefallen Test conditions not yet fulfilled
Error code: 4B E3 18 02 00 00 01 25 6C 94 18 6C 28 1B 4C 6B 00 58 00 68
4BE8 4BE8 data (GEARBX_DATA2, 0x1A2)
Error counter: 1
Mileage 222368 km
Error code: 4B E8 18 02 00 00 01 25 6C 94 18 6C 28 1B 4C 6B 00 58 00 68
4DF3 4DF3 data (TORQUE_GEARBX, 0xB5)
Error counter: 1
Mileage 222368 km
Error code: 4D F3 18 02 00 00 01 25 6C 94 18 6C 28 1B 4C 6B 00 58 00 68
49F3 49F3 data (WHEEL_SPEED, 0xCE)
Error counter: 1
Mileage 222368 km
max rail pressure of the recent 10ms 307.21 bar
intaken air mass per cylinder 472.62 mg/Hub
Battery Voltage 14500.44 mV
Error code: 49 F3 18 02 00 00 01 25 6C 94 18 6C 27 1B 4B 6B 00 59 00 68
3F62 3F62 (0500) speed sensor signal ueber CAN
Error counter: 1 Logistic counter: 37
Mileage 222368 km mean engine speed 661.98 rpm coolant temperature 58.16 deg C max rail pressure of the recent 10ms 307.21 bar injection mass index value without mass balance control 11.42 mg/cyc intaken air mass per cylinder 478.92 mg/Hub value of boost pressure 1053.53 hPa linearised APP1 0.00 % Battery Voltage 14337.51 mV Vehicle speed 0.00 km/h atmosphaere pressure 1023.99 hPa
Signal fehlerhaft Test conditions not yet fulfilled Error not occurred yet Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase
Error code: 3F 62 14 02 00 00 01 25 6C 94 18 6C 27 1D 4C 6B 00 58 00 68
4507 4507 (0402) exhaust recirculation regulation, Regelabweichung
Error counter: 1
Mileage 222600 km
mean engine speed 1379.12 rpm
coolant temperature 20.01 deg C
max rail pressure of the recent 10ms 535.64 bar
injection mass index value without mass balance control 28.75 mg/cyc
intaken air mass per cylinder 655.37 mg/Hub
value of boost pressure 1299.69 hPa
linearised APP1 29.13 %
duty cycle - exhaust refeeding actuator 29.93 %
duty cycle - manifold pressure actuator 77.20 %
Luftmasse zu niedrig/positive Regelabweichung
Test conditions not yet fulfilled Error not occurred yet Error would cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase
Error code: 45 07 91 02 00 00 01 25 6C B1 32 46 44 49 68 84 25 26 62 67
Stranger12's Avatar
My Ride: 530d
ECU 2
Date: 16.03.2015 21:40:57
ECU: D50M57C0
JobStatus: OKAY
Variant: D50M57C0
RESULT: 1 error in error memory !
4252 4252 Glow plug zylinder 5, Ansteuerung
Error counter: 1
Mileage 223208 km
mean engine speed 717.14 rpm
coolant temperature 47.11 deg C
max rail pressure of the recent 10ms 346.59 bar
injection mass index value without mass balance control 6.70 mg/cyc
intaken air mass per cylinder 485.22 mg/Hub
glow requirements 153.00 -
Unterbrechung Test conditions fulfilled
Error present now, but not yet stored (debouncing phase)
Error code: 42 52 44 02 00 00 01 28 6C FD 1A 61 2C 11 4D 68 00 4B 00 99 ======================================
Gear Box :
Date: 16.03.2015 21:33:59
ECU: GS19A
JobStatus: OKAY
Variant: GS19A
RESULT: 2 error in error memory
5150 messeage from the Trailer Module is missing
Error counter: 61
1. Umweltsatz Mileage 222344 km
time after reset/ignition OFF-ON 7650.00 ms
Battery Voltage 11.52 Volt
Standard safeguard ACC (0=OK, 1=Error) 0.00 0/1
Standard safeguard CAS (0=OK, 1=Error) 0.00 0/1
Standard safeguard DME3 (0=OK, 1=Error) 0.00 0/1
Standard safeguard DME2 (0=OK, 1=Error) 0.00 0/1
Standard safeguard DME1 (0=OK, 1=Error) 0.00 0/1
Status S-switch CAN (0=OK, 1=F/ES) 1.00 0/1
Status Tip-switch CAN (0=OK, 1=F/ES) 0.00 0/1
Status Position ser. line (0=OK, 1=F/ES) 0.00 0/1
Status Position CAN (0=OK, 1=F/ES) 1.00 0/1
Status Driver`s door CAN (0=OK, 1=F/ES) 0.00 0/1
Status Driver`s seat CAN (0=OK, 1=F/ES) 1.00 0/1
Status Key CAN (0=OK, 1=F/ES) 0.00 0/1
Status Kl15 Signal CAN (0=OK, 1=F/ES) 0.00 0/1
2. Umweltsatz
Mileage 222368 km
Battery Voltage 13.92 Volt
# Status Position CAN (0=OK, 1=F/ES) 1.00 0/1
3. Umweltsatz
Mileage 223184 km
time after reset/ignition OFF-ON 5940.00 ms
Battery Voltage 13.84 Volt
#Standard safeguard ACC (0=OK, 1=Error) 0.00 0/1
standard safeguard DME2 (0=OK, 1=Error) 0.00 0/1
Error CAN-Message Test conditions fulfilled Error present now and already stored Error would not cause a warning lamp to light up
Error code: 51 50 68 00 00 00 00 3D 28 6C 91 FF 90 00 94 6C 94 FF AE 00 94 6C FA C6 AD 00 94
5140 Message from the DME/DDE is missing
Error counter: 13
Logistic counter: 38
1. Umweltsatz
Mileage 222344 km
Engine speed 0.00 rpm
2. Umweltsatz
Mileage 222368 km
Battery Voltage 12.40 Volt
Engine speed 640.00 rpm
3. Umweltsatz
Mileage 223184 km
time after reset/ignition OFF-ON 1500.00 ms
Battery Voltage 11.28 Volt
Error CAN-Message Test conditions fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up
Error code: 51 40 28 00 00 00 00 0D 26 6C 91 FF 90 00 00 6C 94 FF 9B 00 14 6C FA 32 8D 00 00
Functional Jobs
Date: 16.03.2015 21:44:52
Model: E60 Scope: all control module
JobStatus: OKAY
Quantity: 33
ADR Gen. name JobStatus 90 VIRTSG90 ERROR_ECU_SERVICE_NOT_SUPPORTED 91 VIRTSG91 ERROR_ECU_SERVICE_NOT_SUPPORTED 92 VIRTSG92 ERROR_ECU_SERVICE_NOT_SUPPORTED
ADR Gen. name JobStatus Number of errors Error code Kind of error 00 ZGM OKAY No Error stored
01 SIM/SGM OKAY 2 Error stored 93C5 20 93FC 20
02 SZL OKAY No Error stored
05 STVL/TEFA OKAY No Error stored
06 STVR/TEBF OKAY No Error stored
0E SFZ OKAY No Error stored
12 DME/DDE OKAY 1 Error stored 4252 44
17 EKP OKAY 1 Error stored CED4 E8
18 EGS OKAY 1 Error stored 5150 68
29 DSC OKAY 5 Error stored 5F56 A0 D354 A4 D355 A4 D356 A4 5E8C E0
36 TEL/MULF OKAY 1 Error stored D690 20
3B NAV OKAY No Error stored
3C CDC OKAY No Error stored
40 CAS OKAY 3 Error stored A0B2 20 A0B5 24 A0B0 28
41 DWA OKAY No Error stored
43 POW OKAY No Error stored
44 SHD/MDS OKAY No Error stored
45 RLS OKAY No Error stored
60 KOMBI OKAY 7 Error stored A3AD 20
A3AF 20 A3B2 20 A3AC 20 A3AA 20 A3B9 20 E104 20
62 MOSTGW OKAY 1 Error stored E18D 20
63 MMI/CCC OKAY 1 Error stored ABCA 20
64 PDC OKAY No Error stored
65 BZM/SZM OKAY No Error stored
67 ZBE OKAY No Error stored
70 LM OKAY 1 Error stored E53E 60
72 KBM OKAY 3 Error stored A41A 20 A41A 20 A44A 20
73 CID OKAY No Error stored
78 KLIMA OKAY 5 Error stored E719 24 E714 24 E716 24 E718 24 9C54 21
A1 SBSL OKAY No Error stored
A2 SBSR OKAY No Error stored
Old Mar 16, 2015 | 04:21 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
I would start at the battery. Did you program and register the new battery correctly. If so put it on a trickle charger on it. Next I would check the alternator. I see a message about charging. Did you have any of these messages before the issue. Once I check the power I would clear the codes to see what I am actually looking for. Clear the codes and see what comes back. Then troubleshoot from there. Right now it seems you have a power issue and when you have that it could give you false codes due a power shortage
Old Mar 16, 2015 | 09:05 PM
Stranger12's Avatar
My Ride: 530d
Hi
Many thanks for reply
Yes issues were there prior to battery change and hence why i changed a perfectly fine battery
It is110ah and an upgrade of 20ah compared to the old battery
All registered and changed in dis
Old Mar 17, 2015 | 06:02 AM
Disconnect the IBS and see if it resolves your issue. Go to the battery and there should be a plug plugged into the negative battery terminal. If your car doesnt work as normal then your IBS is not the issue
Old Mar 17, 2015 | 06:04 AM
Stranger12's Avatar
My Ride: 530d
Had a look but not seeing anything plugable to negatice lead , are you sure that is where itnis ? How big is it , does it have any puctures etc
Old Mar 17, 2015 | 06:05 AM
You might have to jump the car to get it going. You have a lot of error messages which is pointing to a power failure
Old Mar 17, 2015 | 06:21 AM
Stranger12's Avatar
My Ride: 530d
It switches on and fault is intermittent
Old Mar 17, 2015 | 06:28 AM
Look at
and you can see the plug coming into the negative cable as he pulls it off. What switches on and fault is intermittent
Old Mar 17, 2015 | 06:37 AM
Stranger12's Avatar
My Ride: 530d
one of the earlier posts said to jump start and I said the car does switch on and fault is intermittent .
the fault is not preventing the car from switching on always and only does it sometimes.
when it happens the issues are
1. no crank at all but battery fully charged
2.crank but no start
