E60 pre lci xenon to pre lci dynamic
My Ride: Bmw e60 pre lci se
Hi i just fited headlights from pre lci xenon to pre lci dynamic xenon i dont need the extra function to work just needed new headlights. Everything works beside the auto leveling mybe i need to change some wire ore something?
Thanks for replaying so if i had it on old headlights the self leveling it should be working now aswell ore does something needs to be changed?
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Yes things need to be changed. That's a different module all together to get it to work then coding and programming. If I'm not mistaken also the pinout is different. If you just wanted the headlights to work I would just stay with how it is. They work unless you are good with coding
My Ride: lexus LS
Greetings. I carried my vehicle to the nearby carport for an intermittent vehicle check, and they said my headlights where excessively "hazy", they appears to be okay to me, possibly a little greyish yet nothing really awful. I can likewise check that the I have water entrance in both, can see indications of water buildup on the front signals and some in the actual headlights. Kodi nox
mathew_rt
08-27-2014 01:52 PM
medik13
04-14-2011 03:30 AM
