E60 Pre LCI Headlamp QUESTION
Old Aug 26, 2010 | 07:17 AM
dmateo's Avatar
My Ride: 06 530Xi
Have an 06 530xi. What size are the bulbs are they D2S or D1S? It has the Adaptive Xenon Headlights. And if they are D1S will the D2S bulbs work?
Old Aug 26, 2010 | 07:40 AM
NYC530XI's Avatar
D1S. D2S will not work, as they are completely different animals.
Old Aug 26, 2010 | 07:42 AM
Cwest's Avatar
another way to identify this is the imprint around the headlight housing. There should be an imprint saying adaptive xenon around the projector housing and showing the bulb size.
Old Aug 26, 2010 | 07:57 AM
jas_r_1's Avatar
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights Planned mods: Folding mirrors - Modmynav kit - High gloss shadowline trim -
The imprint could also be wrong.
The only way to be sure is by checking the bulb
Old Aug 26, 2010 | 08:05 AM
nomis_nehc's Avatar
My Ride: BMW E60
Model Year: 2016
Google Osram Bulb Guide.
Old Aug 26, 2010 | 08:26 AM
luigi524td's Avatar
While the on-line guide is usually up to date it's been my experience that some times - not a lot but sometimes - the bulb fitment changes mid-stream.
It's been my experience that taking the time to check out the bulb actually installed in your particular car is the safest way to avoid two trips to the parts counter!
Old Aug 26, 2010 | 11:36 AM
umnitza's Avatar
My Ride: M5
sylvania's guide is not up to date in 10% of the cases, only way to tell is just look right at the top of your car's lights.
If they are xenon, you will know by the way they turn on and the projector, if they are D1S, then you will know by the label that says D1S/H7.
You can retro a D1S to a D2S, not sure if they are the other way around.
Adam1v
Apr 5, 2015 11:40 PM
550iwa
Mar 27, 2015 06:45 AM
andymax
Mar 13, 2015 10:51 AM
bapeforceone
Mar 11, 2015 04:18 PM
dakest
Mar 6, 2015 09:46 AM
