E60 no start & various i-drive faults
Old 03-05-2014, 12:41 PM
g7groupuk's Avatar
Default E60 no start & various i-drive faults
Hi all,
I am having problems starting my BMW 535d E60.
I receive alot of messages on the idrive screen. I try and start the engine but it will not start. - The errors are:
- Control systems! Drive moderately
- Cruise Control Failure!
- ELV engaged! Move steering wheel!
- Fog light front right failure! (This is a genuine fault I am aware of: bulb needs replacing)
- Restraint system faulty!
- PDC failure!
I have also had a fuel pump fault.
It seems to be a electrical fault but I have no clue. I have tried replacing the DDE relay like has been suggested on the forums, but still nothing.
Has anyone experienced anything like this before?
Attached Thumbnails E60 no start & various i-drive faults-photo-05-03-2014-21-29-00.jpg
Old 03-06-2014, 05:36 AM
pcy
pcy's Avatar
Charging system - battery, alternator, and related components.
If you have a voltmeter, check the battery voltage with engine off and then the voltage while the engine is running.
Old 03-06-2014, 05:38 AM
Gee_115's Avatar
My Ride: 07 550i Sports Package
Give the battery a good charge or replace then try again. This all points to a low voltage issue.
Old 03-06-2014, 05:47 AM
Munki's Avatar
My Ride: 545i, 07' gallardo, 12' s65
When you try to start the car does it keep trying to turn over or does it just do nothing at all?
If it does nothing it might be something electrical like battery, but if its actually trying to turn over when your turning the key than maybe your fuel pump is bad?
Old 03-07-2014, 03:40 AM
g7groupuk's Avatar
Thanks for the suggestions guys.
Yes the car does attempt to turn over.
I have tried taking the battery out and charging it using a battery charger to full and still the same.
Is there anyway to test the fuel pump?
Old 03-07-2014, 05:29 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
How old is the battery? E60 is a power hog.
Old 03-07-2014, 05:59 AM
pcy
pcy's Avatar
Disconnect the IBS connector and see if the car starts.
Old 03-07-2014, 07:55 AM
g7groupuk's Avatar
I tried the IBS sensor. Still no start.
Battery is at least 5 years old. The battery charger says it is 100% full and I get a reading of 12 volts from it.
Old 03-07-2014, 09:05 AM
pcy
pcy's Avatar
12.0 Volts is NOT 100% charge on an automotive battery.
Old 03-07-2014, 11:32 AM
ncsugrad2006's Avatar
Have you checked under the spare tire to confirm it isn't wet? There are several computers under there. When the sunroof drains get clogged, water backs up into the trunk and drains to the lowest point, which is precisely where several computers are. One is the IVM I believe which could cause all kinds of stuff
Best engineering in the world my ass..
Quick Reply: E60 no start & various i-drive faults
