E60 Multimedia not working after replacing the blower motor
Old 05-29-2022 | 07:44 PM
bimerguy's Avatar
My Ride: BMW 528I
Default E60 Multimedia not working after replacing the blower motor
Hello guys,
So I replaced the blower motor myself and had the battery unplugged before replacing the blower motor. I replaced the blower motor and put everything back and now my multimedia screen or sound won't come on. There is a sos no phone sign on the dash.
Any suggestions?
2010 BMW 528i Canada
Old 05-29-2022 | 08:17 PM
seanjordan20's Avatar
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
Take it back apart you didn't plug something back in
Old 05-29-2022 | 08:20 PM
bimerguy's Avatar
My Ride: BMW 528I
I did three times, there are only three connectors for the radio and I plugged them all, plus I checked the fuse on the back of the radio under the big plug it seems fine. Is it possible that I screwed one of the connectors, I was gentle while removing them though.
Old 05-29-2022 | 08:22 PM
Model Year: 05 530i
Engine: 3.0 M54
No the connectors only go in one way so I doubt you messed the connector up. Check the fuse in the trunk to see if it blown
Old 05-29-2022 | 08:44 PM
bimerguy's Avatar
My Ride: BMW 528I
Is there a specific fuse I am looking for?
Old 05-29-2022 | 08:58 PM
Model Year: 05 530i
Engine: 3.0 M54
You're going to have to check your fuse card. I know mine is 79 in the renin but I have a 2005. 2010 have a different fuse box than mine
Old 05-29-2022 | 09:08 PM
bimerguy's Avatar
My Ride: BMW 528I
Here's the fuse card I have checked the marked fuses already and they are fine
Old 05-29-2022 | 09:11 PM
bimerguy's Avatar
My Ride: BMW 528I
I did move the center arm rest back a bit, can it be that the connection for the knob might gotten affected or something?
Old 05-29-2022 | 09:18 PM
donpb's Avatar
My Ride: '06 530i N52
If you're unsure, then check them all. Use a multimeter, fuse tester or circuit tester and it'll take 1/2 second per fuse. If you're pulling them and checking visually, that will take forever.
Old 05-29-2022 | 09:22 PM
bimerguy's Avatar
My Ride: BMW 528I
I will do that, thankyou. And what about that center knob? Can moving the center console a bit back damage anything?
Quick Reply: E60 Multimedia not working after replacing the blower motor
