5Series.net - Forums
-   -   E60 Lighting Problem!? (https://5series.net/forums/e60-discussion-2/e60-lighting-problem-142434/)
hmilycar Jul 6, 2015 11:24 PM
Hi all,
After attempting to fit LED bulbs to the courtesy lights that are located at the bottom of the driver/pass doors (The ones that light up the pavement when you open the door) I ended up tripping both sides by touching a screwdriver against the contacts.
I've had a look in the fuse boxes but can't find the fuse they belong to.
Both sides seem to work independantly (I tripped the drivers one before touching the pass one) but I now need to bring them back to life even if it's on the old bulbs.
Any suggestions on how to reset or where the fuse is located?
2015 Latest Version Launch X431 Diagun Full Set OBD2 Diagnostic Tool +3 Year WRT
2015 Latest version! Multi-Language Software for your option!
100% New! High Quality!
Shipping 4-8 working days to Worldwide!
FREE Lifetime Update by email !
3 Year Warranty !
All other interior lighting is working and there are no errors on the i-Drive or the OBC
twh Jul 7, 2015 12:29 PM
Inside of trunk lid has the fuse map.
