E60 lighting issues
Old Sep 29, 2015 | 07:16 PM
smileydawg's Avatar
My Ride: 05 bmw 525i
Default E60 lighting issues
Hey guys I need some help with my e60 my dome lights keep flickering or dull or low at times like it's barely on and then sometimes it would be on. My passenger door lamp use to do it first then it started working an moved to the rear dome light now both dome lights are doing it. Also one of my lowbeam headlamp keeps blowing out or burning out either side. It was working but it also recently started doing this for the pass few weeks. I replaced like 4 bulbs in totally in the pass 2 weeks. I checked for fray wires an it is all gd. I have a holagen model 05 525i like 8 months ago I swap an put in a hid kit with a capacitor and it was working until recently the harness kept burning out so I switch to the error free cree leds to see if that would work but the same thing is happening both would be on for a few days and then one will burn out any side. Does any one know what I can do to fix this or where to look ? An thank you in advance
Old Sep 30, 2015 | 06:36 AM
InsipidMonkey's Avatar
Certainly sounds like a wiring issue.
BMW wiring diagrams here: BMW Online Wiring Diagram System (WDS) by BMW-Planet.com
Need to use IE or Firefox as the site uses an outdated version of Java.
Good luck!
Old Sep 30, 2015 | 07:07 AM
smileydawg's Avatar
Thank you
Old Sep 30, 2015 | 07:13 AM
smileydawg's Avatar
Good luck!
I thought it might of been the lcm going bad.
E60Japanese
Mar 23, 2015 05:23 PM
ooshishi
Mar 17, 2015 02:48 PM
laz1left
Mar 11, 2015 11:15 AM
WolkuZ
Mar 9, 2015 11:19 PM
