E60 LCI 2008 Adaptive Headlights Retrofit
Hey,
I want to get the AHL retrofit on my E60 LCI 2008 along with the headlight washer system.
Can anyone advise if it can be done?
If it can be done, does it involve some new wiring, and/or changing the entire headlights or is there some type of component installation between the wires and the headlights?
Does the headlamp cleaning system come separately or is it part of the AHL?
Is the cornering light part of the AHL or is it something separate?
Would appreciate any kind inputs since I am confused!
Anything can be done if you willing to do it ... so let see how to attempt to do both of your plan. What's kind of headlight you have Halogen or Xenon?
Washer system is not part of AHL. Cornering light is part of AHL.
You'll need new headlights that is AHL capable (Headlight that is adaptive capable has 'Adaptive' wording around the ring of the Xenon lens)
You'll need wiring from both headlights to the LCM which control the stepper motor. You may need new LCM that is AHL aware.
You'll need a new AHL module for each headlight (another reason you need AHL headlight 'cuz otherwise no plug for AHL module under the headlight)
You may need new steering sensor since it's the one that make the adaptive lights turning and maybe also the new headlight cabin switch.
Among all of them (maybe more) probably coding is the easiest part.
GL!
GL!
Hey,
GL!
GL!
I currently have the standard halogens on 'em.
I spoke to the BMW Dealer here - they declined the thought saying that BMW doesn't offer this as a retrofit option on my vehicle!
As I understand, I will need the AHL, wiring kit, a new LCM, AHL module and a steering sensor.... where do I get these from and what should I search for?
Thanks a million for all the help.
Cheers
My Ride: 2012 535i M-Sport
You'll also need a few body sensors that monitor suspension height and activity. I am not sure if there is an SZL specific for AHL or not - seems the steering angle is constantly monitored by a few systems in the car, so I don't see why that wouldn't carry over.
I really don't imagine this would be a cost or skill prohibitive venture as many of the E90 and E46 guys have already gone down this road.
Check out realoem.com for specific parts needed, also look at WDS (google WDS) for the specific wiring path's.
Once you have collected a list of the parts needed, you'll find them all online, used for a fraction of retail cost. Now that the E60 is aging - junk yards are like a toy store to me
Once you have collected a list of the parts needed, you'll find them all online, used for a fraction of retail cost. Now that the E60 is aging - junk yards are like a toy store to me![Twoup](https://5series.net/forums/images/smilies/imported/twoup.gif)
My Ride: BMW 525d (E60) M Sport LCi
Hey Atif_khalid, I know its been a few years now. How did this retrofit go? I'm thinking of doing the same thing. I already have the AHL Headlights.
Hey,
Administrator
Beemer
33
01-14-2019 05:13 AM
kurtb23
04-22-2015 04:30 PM
