E60 on the hard shoulder
I had the unfortunate experience of getting a heavy goods vehicle's tyre wrapped up in my near side front wheel.
I was doing 70mph on the motorway when the car in front suddenly pulls to the left leaving a bloody big tyre with no sidewalls in my direct way of passage. I could not move to either side due to other road users. I felt the initial 1st bump then nothing. At this point I was probably doing 10-15mph. I started to accelerate and the stearing failed to respond
Then the second bump, at this point I had the unfortunate task of putting My E60 on to the hard shoulder. What a bloody mess one of them gets will make to your car. It ripped off My mudflap, practicaly the whole front wheel was covered in tar/rubber from the tyre. The front wing was out of alignment, the light cluster was also out of alignment and the support bracket broken. I had to spend a couple of hours removing all the tar from around the car.
If you see one of these things coming towards you steer well clear.
Then the second bump, at this point I had the unfortunate task of putting My E60 on to the hard shoulder. What a bloody mess one of them gets will make to your car. It ripped off My mudflap, practicaly the whole front wheel was covered in tar/rubber from the tyre. The front wing was out of alignment, the light cluster was also out of alignment and the support bracket broken. I had to spend a couple of hours removing all the tar from around the car. If you see one of these things coming towards you steer well clear.
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
Damn... sorry to hear your baby got hurt.
Do you have pictures of the aftermath?
Sorry, no pics.
I was in such a hurry/panic to make sure she was OK I spent the first couple of hours on arraival at home dealing with the "carnage".
Luckily no lasting damage. (Apart from My nerves with little steering).
Originally Posted by sleeper' post='445606' date='Jul 10 2007, 11:13 AM
Sorry, no pics.
ABC
In the U.S., they call them "alligator skins" because the tread pattern resembles the skin of an alligator. The trucks (lorrys) here are allowed to use retreaded / capped tires and the damn things peel off far too often. The truck drivers usually aren't even aware of it happening and just continue on down the road leaving a hazard for all that follow. My wife hit one with her minivan and it tore up the front bumper nicely. It's too bad that there isn't a way to trace the the things to their owners and make them liable for the damages they cause.
Originally Posted by e60scotland' post='446157' date='Jul 11 2007, 02:35 PM
Tracing wouldn't be an issue using something like microdots, unfortunatly the cost involed probably means it would never be implimented.
ABC
