E60 Ground Cable No Start
Old 01-24-2019 | 06:51 PM
Valhalla519's Avatar
My Ride: 525I
Model Year: 2009
Engine: N52
Default E60 Ground Cable No Start
Hey everyone,
So my car doesn't start and I replaced the battery this morning. Could this be the culprit? I think so!
Old 01-24-2019 | 07:49 PM
My Ride: 525I
Model Year: 2009
Engine: N52
I was able to get my hand down there and the cable was coming apart when I was moving it around.
Now if I can get access to it...
Old 01-24-2019 | 10:15 PM
pole's Avatar
My Ride: BMW E61 530d
Model Year: 2005
Engine: 3.0d
to verify, make ground with a jump cable, ground the engine to the chassis, at the negative terminal. Basically, this bypasses that broken ground, and you make a new ground.
If it starts, it's the cable, if not, something else, maybe the starter.
Old 01-25-2019 | 01:03 AM
My Ride: 525I
Model Year: 2009
Engine: N52
Alright, so just take the 2 neg ends of the jumper cables and connect from ground bolt to engine?
Old 01-25-2019 | 02:12 AM
pole's Avatar
Model Year: 2005
Engine: 3.0d
exactly. you are basically making a new ground.
have someone try and start the car while you are holding the cable in place, to make sure it has good contact.
Old 01-25-2019 | 05:20 AM
My Ride: 525I
Model Year: 2009
Engine: N52
Tried it and on many spots on the engine block but no crank. I just put in this new Agm battery yesterday and it's reading 12 v and when I push start it goes down to 11.5...and I think I left the IBS sensor connected from the positive to the negative but not back to the ecu so Ill disconnect that just incase.
Also my jumper cables might be crap so I'm going to try a different set .
Old 01-25-2019 | 06:00 AM
pole's Avatar
Model Year: 2005
Engine: 3.0d
12V is on the low side a bit, but still it would at least try to crank the engine.
try to place one clamp of the cable exactly on the spot where the ground cable connects to the engine block, the other on the negative bolt in the engine bay.
But you should consider other options, like the starter... does it try to crank, make any noise whatsoever? Why did you disconnect the IBS?
Tap repeatedly with something on the starter, like a wooden stick or smth, if it cranks after, it's the starter 100%
Old 01-25-2019 | 09:17 AM
My Ride: 525I
Model Year: 2009
Engine: N52
So I set up the ground trick but still no crank. I found out that before when I was tapping the what I thought was starter was actually the solenoid and I don't have a stick long enough to reach the actual starter so I need to get one and try.
I disconnected the IBS when I changed the battery and never re-connected it but now when I did, I got a High Battery Discharge message on the I drive...
I feel like its a mixture of the ground cable because it's corroded and breaking apart and also the starter..I would hope that's it!
Old 01-26-2019 | 05:07 AM
pole's Avatar
Model Year: 2005
Engine: 3.0d
try tapping on the starter, and report back. you should order the cable nevertheless, it's toast.
don't mind that "high rate batt discharge" message, it's because you had the ibs disconnected... unless you did notice the battery is weak, but still, this is not the issue with no crank.
and oh, don't use a metal stick when you tap on the starter, stick with wood, for "positive" reasons.
Old 01-26-2019 | 06:54 AM
My Ride: 525I
Model Year: 2009
Engine: N52
Ok I'll report back when I try to tap the starter.
The battery is brand new so I'm not worried about it. I've got a tow coming Wednesday to get me in so my guy can check what's going on.
By the way, Pole, thanks for all the help!
