E60 FLA High beam assist failed
Hello friends. So, i,m trying to retrofit my E60 with FLA. So my car is 2003 years E60, before it was with halogen headlights, and when I buy it i retrofiting it with LCI Adaptive headlights. Change the LM Module with latest LM2.C36. Everything is working perfect, headlights worked as well. So, my rearview mirror, have only dimming, I buy a mirror with FLA, alarm and garage door. I cant find wiring diagram, abou compas, alarm, garage door, becouse the wiring are different between both mirrors. FLA mirror is from LCI car. So I make Y wiring K-CAN from rain sensor. Later, I write VO in CAS and LMA, then I make default coding, I can see and read the FLA in INPA, I have tick in iDrive menu already, all function in KOMBI, LMA for FLA are active. KOMBI module is updated to the latest firmware. But when I try to read the FLA with ncs expert, always take error. I read it with ISTA+ and it show me No communication with High beam assistant. I don't know what I make wrong. I will upload some photos and video, after instaling FLA, what's happen when I try to active it.
https://mega.nz/folder/tSlXQICI#KLBogMg6daxLJAa1cGsMGg
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
It looks to me like there's a faulty wire somewhere. You're having communication issues with the module. Do you have ISTA to see what it looks like on the tree and to be able call up some functions to check it
Yes I already checked it in ISTA, first time it show Green, but when I called it, then say No communication and show in red.
DragoMPower
05-16-2024 08:11 AM
ViperRunner
04-29-2011 09:06 AM
hamish112
10-09-2009 09:14 AM
