E60 Door Speakers and Subwoofers not working only Rear Shelf
hi there
while installing my new aftermarket amplifier, i first tried to connect the amplifier to the under seat sub woofer passenger side for some reason the left side (passenger) front door speaker and sub woofer stopped working. so i completed the sides wiring anyway.
i then had to use the drivers side under seat subwoofer which when completed gave amazing sound to the amplifier and worked great but the left side still didnt work but it was good enough to listen too.
last week i was reinstalling the subwoofer after i had removed it for a long journey and i saw a spark on the wiring and my right side has turned off as well. now i only have rear shelf speakers that work and nothing else i am going loopy checking all the wiring
i have done a scan and have the following fault codes with inpa
SFZ OKAY
2 Error stored
9AF6 60
9AFF 60
DME/DDE OKAY
5 Error stored
4212 64
4262 64
4687 04
41F2 04
4548 28
EGS OKAY
1 Error stored
51AD 24
TEL/MULF OKAY
1 Error stored
A392 60
CAS OKAY
2 Error stored
D904 20
A0B2 20
RLS OKAY
1 Error stored
DA44 20
ZBE OKAY
1 Error stored
E2C4 20
KBM OKAY
3 Error stored
E584 20
A448 20
A449 20
CID OKAY
1 Error stored
E5C4 20
please help
SFZ OKAY
2 Error stored
9AF6 60
9AFF 60
DME/DDE OKAY
5 Error stored
4212 64
4262 64
4687 04
41F2 04
4548 28
EGS OKAY
1 Error stored
51AD 24
TEL/MULF OKAY
1 Error stored
A392 60
CAS OKAY
2 Error stored
D904 20
A0B2 20
RLS OKAY
1 Error stored
DA44 20
ZBE OKAY
1 Error stored
E2C4 20
KBM OKAY
3 Error stored
E584 20
A448 20
A449 20
CID OKAY
1 Error stored
E5C4 20
please help
My Ride: 2008 Metallic Green 535i,Dakota Brown leather,NAV,HD Radio, Comfort Access,Sport pkg,Premium Pkg,Cold Weather pkg,Logic7,Park Distance, SAT/Paddles, Ipod adapter, tint, LED Side markers, & halos, heated fronts,CPO'd car, tinted tails, heads, reflectors, backup camera, afe cold air intake, led license plate lights, rear lip spoiler, recoded modules: remote folding of mirrors, deleted accept screen on idrive, auto unlocking of door when ignition turned off, closing windows, & sunroof w/ remote, digital speedo on instrument cluster.
What type of system is it? Hi-fi?, Logic 7? From the limited info you gave, could be the amp has been damaged. Did you wire the subs from the trunk harness? What model 5er do you have? Need more info to help.
hi there and thank you for your reply.
My vehicle is 530d SE 2005. I dont have logic 7 or the hifi. My system does not have an amp and only 6 speakers. I wired the amplifier to the subwoofers under the seats so i could have some control of the bass with the idrive.
Forum members Bruce Miranda, or Technic would be far more helpful than I on this matter. I believe you have standard sound system without an amp, but amplified by the idrive. Of you added an amp into the loop, it might have blown something in your radio. Try PMing one of them, especially Bruce, since he is in Europe.
You're welcome. I think you need one more post to be able to Private Message another member. Hope the helps you get your sounds back working.
Awest91
09-17-2022 11:05 PM
