E60 cruise control failure, engine fault reduced power
My Ride: E60
Engine: M54
E60 ‘04 530i
this is a reocurring thing i get, usually happens in longer distances 40-50km in an area with a lot of speed bumps. Usually I get a drive control systems fault and after that its really hard to accelerate normally and if I press the gas a bit harder I get a cruise control failure and an engine fault. The car shakes and tries to move forward when im stopped until i put it in park. The rpms bounce around rapidly around 1-1.3k. I took it to get diagnostics done and it showed a 2nd cylinder misfire. I’ve changed the coils and it was fine for a couple of days, then it started again.
Phantom Mark
12-16-2008 01:22 PM
