E60 Common Problems
Old Sep 18, 2009 | 07:15 AM
bryso90's Avatar
My Ride: 2004 530d
Nice one on the creaking windows , was just about to search the threads . That noise would put your head away lol
Thanks for the post
Old Sep 18, 2009 | 07:22 AM
vlad_b's Avatar
My Ride: 2005 BMW 545i Sport Package, Jet Black M166 OEM Wheels M5 Style Body kit RPI Scoop BMC Air Filter Valentine One Radar Detector 35% tint all around
Thank you for making this post.
First of all, all you listed above is true common problems. I've had almost all that.
1. Noise from sunroof i fixed by changing the seal
2. Creaking windows are bothering sometimes, true
3. Did not have that yet
4. Seals going bad because of sun. Did not fix it yet but nedd to. Also, in California with the black car: i feel like sun is the reason for some creaks in interior. It probably damaging some materials
5. Back seat arm rest! I need to fix that, bothering a lot. For now i am putting a small towell inside there so it makes it tight. But there must be some kind of foam we can put in there, if anyone knows let us know!
Plus, i would add: Control Arms is definatelly a common issue (Vlad_Russian Mentioned that), 124' rims are easy to crack, Transmission issues (like jerking before coming to a stop) at least on 545i, slight rough idle - can be improved by using a proper gasoline.
Old Sep 26, 2009 | 05:47 AM
ottawahull's Avatar
My Ride: BMW 530ix Titanium Grey
Originally Posted by Phantom Mark' post='1010887' date='Sep 18 2009, 05:40 AM
Pah warranty......
The paint was falling off the side mirror supports on my E60, really badly, took it into the dealers expecting to be covered by paint and perforation warranty, nope, its TRIM so not included, pathetic, not even a 4 year old car at the time !!
happened to me too. happened 2 month before warranty expiry date. Btw, is there a grace period? I have a check engine light with no idrive message...would the diagnostic be covered? (I have a certified series until 2011)
Old Sep 26, 2009 | 06:26 AM
JeffNNJ's Avatar
My Ride: 2011 M3 Convertible, Alpine White/black, 6 speed 2011 535xi Tasmin Green, Venetian Beige
Problem: girlfriend won't put out while I drive. Fix: more alcohol.
Old Sep 26, 2009 | 09:08 AM
einstein57's Avatar
My Ride: 05 530i 87 325is 85 VW GTI
Originally Posted by v_therussian' post='1010899' date='Sep 18 2009, 03:37 AM
A few "common" issues I've come across:
1. I'm pretty sure at this point that control arm failures are a common issue. So much so that I've sort of come to consider it a "wear" issue. I'm sure there is a DIY on replacing them, but here's how you'll know they are failing - your steering wheel becomes ultra-sensitive to any minor imperfection on the road and any pothole feels like an explosion just went off under the front of the car. All the requisite noises and rattles will alert you as well. This is due to the flawed design of the control arms' bushings, which tend to wear out too soon. Unfortunately, AFAIK, you cannot replace the bushings alone - you have to replace control arms.
The bushings will run you $74 for oem units. My local independent BMW shop charged me $20 per arm to press them in. Hardest part of the install is removing and installing the strut in order to remove the control arm.
Old Sep 26, 2009 | 09:48 AM
neoe60's Avatar
Is this covered under warranty?
Old Sep 26, 2009 | 06:03 PM
z06bigbird's Avatar
Originally Posted by hmc' post='1010457' date='Sep 17 2009, 04:17 PM
Had a 2006 525 and now 2007 550, I found there are some (very) common (non-software) problems in E60:
1. Wind noise from sunroof
Fix: http://www.bmwtis.com/tsb/bulletins/bullet...mp/B540409g.htm
2. Creaking Windows
Fix: http://www.bmwtis.com/tsb/bulletins/bullet...mp/B510205g.htm
3. Brake pedal becomes hard 30 minutes to several few hours after car shut down.
Fix: Replace Vacuum Pipe. There is no bulletin for E60 but there is one for E90: http://www.bmwtis.com/tsb/bulletins/bullet...mp/B340607g.htm
4. Seal on top of front windshield and around rear window going bad due to lots of sunshine.
Fix: Replace seals, easy DIY, or have dealer to fix if its under warranty.
5. Rattle from back seat central arm rest.
Please feel free to add more from your experience and/or research.
Old Sep 26, 2009 | 06:04 PM
z06bigbird's Avatar
Great resolution for problems with BMW E60s. Thanks.
I will add this to my library.
Old Sep 26, 2009 | 07:05 PM
08white's Avatar
My Ride: 2008 BMW 535XI white
thanks, this is very helpful
Old Oct 20, 2009 | 06:45 PM
JW-BENZ's Avatar
Can the sunroof seal be replaced easily or do I have to go to a dealer. I read that some programing is required??
I have the noise from the sunroof... My correction was to close the shade on it to mute the noise, but I want to have the sun shinning in.
Anyone? Thanks!
