E60 Bluetooth loose connection
My Ride: E60 530i
Engine: M54
My E60 (2005, 530i) recently lost BT connection to cell phone when call is in-coming. It does not happen all the time, about 50%. Out going calls have no problem. Once BT connection is lost, it will reconnect and works again.
What could be the problem ?
Thanks.
Thanks.
My Ride: E60 530i
Engine: M54
No, I am using Andriod phone. BT connection used to be very good; this lost connection issue just showed up in last month or so.
My Ride: 2007 BMW 550i
you'll need ISTA/P or WinKFP and a power supply for the battery. Not something easy if you have no experience with it as you can ruin your car. Take it to an experienced indy that has ista/p he should be able to reprogram the module. Though you should know if the module itself is half dead it wont survive the programming and will probably stop working completely.
