E60 automatic transmission change
My Ride: Subaru
Hi all. I am new to the forum . Need some assistance. can anyone assist with the procedure to code a used egs to a transmission. I dl have bmw standard tools. Thanks
My Ride: 530i
Engine: M54
did you already install the transmission? It's a lot easier to just swap over your old EGS into the replacement transmission, no coding required.
My Ride: Subaru
Hello.thanks for reply. Actually its the egs tht is faulty so i purchase another box which i will take the egs and fit in the original one whicj is showing difgerent vin number.
My Ride: 530i
Engine: M54
try BMWcoding.com. warning, they are NOT hospitable to newbies asking questions that have already been answered. I can guarantee you'll find your answer there, but I recommend signing up and doing a lot of lurking/searching before you post anything.
Here's a thread I found on E90post that might help:
https://www.bimmerforums.com/forum/s...used-TCM-(EGS)
good luck.
good luck.
