e60 Acting Strange After Rain
Yesterday my car was in the pouring rain all day while I was at work. I got off work and drove home just fine even though it took me an hour to get home and was pouring rain. I got up to go to work the next morning and my car wouldn't turn over. I immediately suspected the battery. Called AAA and they took forever to come and the guy said the battery was fine. He tried forever to jump it but failed, repeatedly. I knew he couldn't jump it with his jump pack or his truck battery. He even hooked them both up together and no go.
He left. I looked at the battery and didn't notice anything at first. Then I used a flashlight and saw my battery had an inch or so deep of water surrounding it. Egads. I took my fluid extractor and pumped a good quart of water out. Then the battery measured 8.5V. AAA came back and still could not jump it. I then went and bought a new battery.
Then the car sat stuck at the BMW logo acting all strange. Finally the car decided to start for the first time. Then not start. Then sometimes it starts. Other times when I try to start it or just put the key in, iDrive display will turn off. Its acting really crazy. I'm thinking water could still be somewhere but I can't tell where. Help!
I didn't know any electronics were under there. Most of the electronics I see are in the sides of the trunk and high up.
My Ride: 535xi hud night vision
Model Year: 08
They are there. You need to take the wheel out and remove foam underneath. I would disconnect the battery and take everything out. Wrap the parts in cheese cloth and throw it in a bag of rice then hope for the best. Open up the white box that is for the TPMS system. It’s only got 1 circuit board but doesn’t drain easily. I have replaced it on one of my other BMW’s already
I got lucky a week ago on my e61 as someone had already drilled 2 holes for drainage. Make sure you pull up a diy on how to clean your drains so it doesn’t happen again.
Model Year: 08
That’s good news. It is usually under the foam cover under the tire. Maybe bmw figured out that was a terrible idea and changed their location. https://www.google.com/amp/s/www.bim...t=619320&=1
I am really not sure where else it could be.
You might have to revisit the battery location. There are many fuses and relays situated in that area and some might have been wet by the water getting into the battery well etc..
I'm learning all about this myself recently. Just purchased an E61 from Concord and discovered a 1/4" of water in the battery well in the right rear, and enough water in the spare tire well to float the styrofoam that holds the various electronic modules back there. I had 2 blocked sunroof drain hoses in the D-pillars (aka rearmost column where hatch is) at the bottom, and left hose was loose on the nipple that attaches the hose to the sunroof drain channel up in the headliner area. Used gasket maker to seal hose to nipple, blew out all the gunk, and no longer have any leaks. Lucky I got to it before things shorted. I also had to clear the 4 different drains in the engine compartment and checked the 2 front sunroof drains, which were okay, and that drain near the front door hinges (on the wagon anyway). Use compressed air to blow dry the fuse panel and anything else back there.
Previous owner has maintenance receipts showing 12V batteries being replaced, remote fobs not working, and rear glass hatch not functioning, all intermittent issues, which is all likely related to water ingress back there and in the hatch electronics. Recommend you look hard for sunroof and other leaks, plus use a water hose to test everything. Water and electronics do NOT mix well.
