E60 6speed gear rattling sound NORMAL!?!?
Old 09-09-2008, 06:05 PM
txphi592's Avatar
I took my 05 530i in to get some things fixed (48k mileage) under warranty before it expires.
One problem is when I turn off the engine, sometimes I hear a quick rattling sound (almost sounds like fan blades hitting something) coming from under the car. The sound only lasts for a second or so, but it is audible and sounds ghetto.
The dealer tells me this is "normal" on manual transmition cars like mine. They say it is a "gear rattle" noise, and if I engage the clutch when turning off motor it shouldnt happen. I don't know about you, but I don't think a 50k car should be making "gear ratteling" noises and accepted as normal operation with no fix from the dealer.
Please advise. Thanks!!
Old 09-09-2008, 06:10 PM
bimmer530iguy's Avatar
My Ride: 5series
WOW! I have the exact same problem with my 530i, which is also a manual transmission and it started about 6 months ago.. I currently have 32k miles, so it could be just a gear rattling but I never had this problem when I first got the car, It makes a shuddering noise right after I turn of the engine.
Old 09-09-2008, 06:16 PM
txphi592's Avatar
Exactly! I want this fixed and I don't care if they have to replace the whole tranny! What do you guys think, is this acceptable for the dealer NOT to fix under warranty???
Old 09-09-2008, 06:22 PM
My Ride: 5series
Yea, I really hate this noise too. It makes the car sound like the engine is dying. The Dealer wouldn't fix this problem when I asked them too, so I am going to take it to my friends shop soon, and ask him to check it out, will keep you posted.
Old 09-10-2008, 02:10 AM
sy1616's Avatar
This the same for the 545i with a 6 speed because I don't have that noise?
Old 09-10-2008, 02:49 AM
BigMike's Avatar
My Ride: E60
That sounds nasty! Have them check it to make sure! Perhaps remind them that if there's a problem
in the near future and it gets traced back to this, they'll have to pay for replacing it! heheheh
Old 09-11-2008, 03:48 PM
txphi592's Avatar
I did have them check, they are trying to tell me it is normal to have a BMW make GEAR RATTLE noise when turning the car off without clutch engaged.
What should I do if they continue to refuse to fix this?
Old 09-11-2008, 04:12 PM
ObD
ObD's Avatar
My Ride: 2008 535i 6MT
If you depress the clutch when shutting off the engine does the noise go away?
Old 09-11-2008, 05:35 PM
txphi592's Avatar
They SAY if you press the clutch in when turning off the engin noise goes away. I use ebrake, I don't leave car in gear, so my clutch is not pressed in when i turn off motor.
Old 09-11-2008, 08:38 PM
ObD
ObD's Avatar
It's normal. I just push the clutch in when I stop the engine. My E90 3'er made the same rattle until I read in an online forum to push the clutch in. You do realize the e-brakes can fail. In my work garage we've had a few creep out into the traffic lanes.
Quick Reply: E60 6speed gear rattling sound NORMAL!?!?
