E60 545i engine rough P0430 lambda sensor error. time for a new cat?
My Ride: BMW 550i
Hi everybody,
i've got a light vibration on e60 545i 4.4 v8 engine when on idle as well as fuel consumption increased, sometime later engine light popped up, when scanned appeared P0430 error which is post cat lambda sensor fault on bank 2 (5-8 cyl). scanned with dis fault came up as "CATALITYC-CONVERTER CONVERSION, BANK 2 CATALITYC-CONVERTER EFFICIENCY BELOW THRESHOLD" when cleared fault it won't appear anymore (have done over 100 miles since that) but engine still a bit rough on idle with mpg dropped
now wondering is it time for a new cat or just lambda?
any advise appreciated.
thank you
thank you
My Ride: Orient blue '05 545i, Sport/Premium Pkg, 6Speed MT, Xenon, Navi, Blue2th, PDC,
Hi everybody,
thank you
thank you
When O2 sensor is bad it will provide crazy data to the computer - that would cause increased fuel consumption and rough idling
If you don't need to - don't replace the cats!
You may need to reset the codes and fuel adaptation values after the repair.
Good Luck!
My Ride: BMW 550i
the problem was part of substrate inside cat was broken/missing about half of it so this caused post cat lambda error. it is easy to spot on E60 545i V8 N62 as you only need to disconnect main exhaust from cats without removing it push it a bit on one side then investigate with torch what is happening inside cat. i have replaced both cat + post cat lambda and no problem since
My Ride: 2005 545
My Ride: 545i sport
Yes, BMW calls the Oxygen sensors Lamba (or lambda?). Probably started with Bosch. Refers to greek symbol used in technical documents.
BTW, the post cat sensors have no impact on how the engine runs. They are merely monitoring sensors and have no direct input to the control of fuel air mixture. That is the job of the pre-cat sensors.
linxuan
E39 Discussion
03-22-2015 06:16 AM
