E60 545i Electrict problems Help
Hello Dears,
I have been having electrical problems in my car BMW 545i E60 2004 and i dont now how solve them and i would like to have any help from someone here, the problems starts fews weeks ago with the battery Charging Fault message i was thinking that my battery was not good so i change the battery and the problem continued i did a diagnostic with Disv57 and get the message that the alternator was with defect so i went to the mechanic and change the alternator the problem seems to be solved because the battery is now chargging but im getting alot of other errors for example the lighting fault and painel lights that are not working the flashes are not working too also the radio is not working so i did another diagnostic to try clear this error and the error that are not allowed me to clear are the followings:
DME - 2746 DME
DME - 2745 DME
DME - 2743 DME
DME -283A DME
DME - 27A0 DME
DME - 28D7 DME
DME - 2783 DME
DME - 278C DME
DME - 299B DME
DME - 2774 DME
DSC - 5F49 DSC
AHL - A58A AHL
AHL - A589 AHL
AL - 31A AL
AL - 6145 AL
AL - 6133 AL
AL - 612C AL
AL - 6140 AL
PDC - 9E39 PDC
PDC - 9E31 PDC
AHM - 9DF7 AHM
ACC - 5D14 ACC
EGS - 4F89 EGS
SFZ - 9AFF SFZ
I hope that someone can help me to solve this problems because before starting the battery issue problems was not kind of this error everything was working fine.
I did not registered the new battery because i dont know how to do it on Disv57 program.
Thanks in advance for your help
DME - 2746 DME
DME - 2745 DME
DME - 2743 DME
DME -283A DME
DME - 27A0 DME
DME - 28D7 DME
DME - 2783 DME
DME - 278C DME
DME - 299B DME
DME - 2774 DME
DSC - 5F49 DSC
AHL - A58A AHL
AHL - A589 AHL
AL - 31A AL
AL - 6145 AL
AL - 6133 AL
AL - 612C AL
AL - 6140 AL
PDC - 9E39 PDC
PDC - 9E31 PDC
AHM - 9DF7 AHM
ACC - 5D14 ACC
EGS - 4F89 EGS
SFZ - 9AFF SFZ
