E60 545 Transmission Support Group
Old 01-19-2007, 08:11 AM
BMWNA's Avatar
Originally Posted by BMWing' post='377917' date='Jan 14 2007, 01:09 AM
I have had problems with my 2005 545 Steptronic transmission since the day I purchased the car. The transmission alone is ruining my driving experience. :thumbsdown: I have had all of the CIP updates and it has been in the shop 6 times over the past 18 months and still can?t get rid of the SLAM and hesitation when accelerating from a rolling stop. Is anyone else still having this problem? :'( I think we need a support group for this.
I?m with BMW of North America, LLC. I?m sorry to read about this problem with your 545i. We are here to work with you and your BMW center, and we'd like to help. If you would like our assistance, please phone us at (800) 831-1117 or email us at CustomerRelations@bmwusa.com, and mention Reference #200701901043 so that we can help you more efficiently.
Old 01-19-2007, 08:24 PM
BMWing's Avatar
My Ride: 2005 545 Fully Loaded 2005 X5 Fully Loaded
Originally Posted by BMW NA Customer Relations' post='380588' date='Jan 19 2007, 09:11 AM
Really? Is this for real? I will call...Thanks!
Old 02-17-2007, 10:50 AM
BMWing's Avatar
BMW has contacted me and is still gathering data from my dealer. Will keep you posted.
Old 02-17-2007, 01:50 PM
homerrs's Avatar
This is the bulletin that I showed my service department when I had issues with the "Slam" issue.
They upgraded to 23.02 and this eliminated my eyebrows. This eyebrow issue has since been fixed with 24.00.
They also had a laptop sent to them from BMWNA to reprogram the transmission. This was back in December 2006. I had the "slam" one time after that and it's always at the same location/stop.
Hopefully this helps you.
SI B 24 03 05
Automatic Transmission
JUNE 2005
SUBJECT
Harsh 2-1 Downshift
MODEL
E60 (545i); E63/64 (Ci?Cic) with 6HP26 up to 04/05
SITUATION
Customer may complain of the following:
^ An excessively harsh 2-1 downshift when decelerating to a stop, or
^ Transmission "bangs" into gear wen accelerating from a full or "rolling" stop (vehicle did not come to a complete stop).
CAUSE
EGS software.
CORRECTION
On a customer complaint basis only, reprogram/recode complete vehicle ussing SSS with CIP on-line update 17.01, or higher.
Important: Transmission temperature must remain below 50 deg C and trans shifter must be placed in P position prior to the start of the CIP) programming.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty
Old 03-14-2007, 07:00 AM
Wildcat's Avatar
My Ride: 2005 545i, Orient Blue/Beige, Navigation, Premium Sound, Cold Weather, PDC, split-folding rear seats, DIY iPod. DIY Valentine 1 hardwire, loose nut behind the wheel.
Does anyone experience any actual loud banging noises when they get the transmission slam, or is it a more tactile sensation (in the seat of your pants). I've never heard a bang in the tranny per se, but I'm wondering if the take-off hesitation issue some of us are having is what others are referring to as transmission slam. If they are two distinct problems, it's possible that the take-off hesitation is BMW's "fix" to the slam issue.
One way or the other, I'll have to find a solution to both the take-off hesitation and the smooth stop issue before I will truly be able to enjoy this car. Has anybody had any luck correcting either of these problems?
Old 03-14-2007, 07:45 AM
KAF
KAF's Avatar
Model Year: 2015
Engine: N55
No bang just the rocket ship lauch after the delay.
Old 03-14-2007, 07:54 AM
aybeesea's Avatar
Interesting if without the turbo. Or, in these sitautions, have the revs built up enough for the turbo to be operational?
ABC
Old 03-14-2007, 08:41 AM
KAF
KAF's Avatar
Model Year: 2015
Engine: N55
ABC
It's transmission not turbo, the normally aspirated 545 and 550 suffer as well.
ZF acknowledge the 'feature' it is because the car stops in 2nd, tries to then take off in 2nd but the ''brain' realises the acceleration demand means it needs first. It then selects first and off you go, like a bat out of hell cause you kept pressing the gas waiting for something to happen.
The whole process creates a delay in moving off of around .5 to .9 of a second, but it seems like much longer.
Especially when pulling out into traffic, which at 60mph is covering 90 feet per second.
There is a big difference between pulling out when a car travelling at 60mph is 180 feet away and pulling out when it is 100ft away.
:thumbsdown:
Old 03-14-2007, 08:54 AM
dlevi67's Avatar
Entirely agree it's transmission and not turbo-related - the problem disappears by manually selecting 1st gear or (to a lesser extent) DS when stopping, but it's not exactly convenient. Especially since the so called manual mode is so nannied over that it's almost impossible to use.
Old 03-14-2007, 09:01 AM
aybeesea's Avatar
It wasn't the cause rather the effect described as "ROCKET SHIP" which I find hard to relate to a non-turbocharged diesel - even in first gear and a 3-litre engine.
ABC
Quick Reply: E60 545 Transmission Support Group
