E60 545 needs an exorcist (possibly electrical problems)
Hello guys my car is going crazy !!
I致e changed the generator/altenator and did check the cable from generator to dme and all the fuses and they are ok
Does anyone have any idea what can be the issue?
What should I check? Or change?
Btw sometime I have the error 28d7 dme can稚 communicate with generator and the car misfires
覧覧覧覧覧覧覧覧覧覧覧
00932A ZGM/SGM-ZGM: BYTEFLIGHT communication error
S 0180 No communication possible with: Safety module/restraint system
S 0193 No communication possible with: Steering column switch center
S 0187 No communication possible with: Door module
S 0189 No communication possible with: Door module
S 0177 No communication possible with: Satellite vehicle center
S 0129 No communication possible with: Engine electronics or Diesel
Hybrid
S 0758 Permanent SAE error code (non-continuous) stored
00CE99 Message (steering wheel angle, 0x0C8) faulty, active steering receiver, SZL
S 0616 Programming aborted: Telephone control unit
00А3В3 Message (active roll stabilization, 0x0BE) faulty, receiver
KOMBI, ARS control unit
00A3A9 Message (steering column button signal, 0x1EE) faulty, receiver
KOMBI, SZL control unit
00A428 KBM: Windscreen wiper motor blocking protection
009C77 IHKA: Additional water pump
009C79 IHKA: Water valve control unit
009C7A IHKA: Right water valve
S 0172 No communication possible with: Control unit Satellite B-pillar
S 0174 No communication possible with: Satellite B-pillar right
覧覧覧覧覧覧覧覧覧覧覧
Hybrid
Engine: 3.0 B58; 3.0 M54
The first thing I would have checked was the MPM in the trunk. Should be where the spare tire is. Little grey/white box. Unplug it and see if there any corrosion on the connectors. Also look at it and see if there's any water damage. Next I would have check the battery and then grounds in the engine bay. Between all those you should find your issue
I did new battery registration and I don稚 have now the histogram 😅 but battery voltage was 12.2 charging at idle was 13.9 I致e had the car for almost 1 hour in use and the battery was at 12.4 I assuming that痴 not normal
Ooh you're off on voltage. You need to be around 14.7v. 13.9v is low especially on a reset. You're still having the same electrical issues?
