E60 535d with 6sp manual
#41
Originally Posted by skaffa' post='359336' date='Nov 22 2006, 11:12 PM
It does not matter which RPM You have Nm is always same Nm regardles of RPM.
Why this is like urban legend that high RPM torque is different than low RPM torq? In stress point of view it's same.
Skaffa
Skaffa
For example:
1st scenario: needle is at 4500rpms and you change gear, push the clutch pedal, select higher gear, neddle drops to around 3000rpm, lift off the clutch, reapply 100% throttle. When you reapply throttle at 100% (assuming you don't lift off more than 20%) the torque delivered by the engine has a particular value X.
2nd secnario needle is at 2000-2500rpm, you drive more relaxed, and shift to a higher gear, and after the shift rpm drops to 1000+rpms and you apply after that almost the same throttle as in scenario 1. Now the engine delivers a higher torque Y value than in scenario 1. Y>X
So considering this will often happen the stress will not be the same on the clutch.
#42
Skaffa
Skaffa
#43
Originally Posted by dlevi67' post='359360' date='Nov 23 2006, 12:20 AM
100% correct. However, most people at most times use their cars in the lower half/two thirds of the rpm band. So it's likely that an engine with a very peaky torque curve (M5? ) will actually put less stress over time on the gearbox than an engine with very high torque at low revs (335i?)
#44
Originally Posted by BetterMakeWay' post='359364' date='Nov 22 2006, 08:28 PM
Or better yet the 535d/335d because the rev range is wider and peak torque sits lower+the higher diesel torque values. That was what i was trying to say.
Actually, an old Volvo 480 turbo would have been as good an example as the 335i.
#45
Originally Posted by dlevi67' post='359375' date='Nov 23 2006, 12:38 AM
Ah, yes. But have you seen the 335i's torque curve? It's totally - and I mean totally - flat from about 2000 rpm to 5000. And I was trying to avoid to turn this into yet another "Diesel v. Petrol" comparison!
I don't think we were getting into a diesel vs petrol dbate. No petrols have been discussed and the topic is about the manual 535d. So we were on track
Sorry i don't know that volvo or i know very little. What was the production year of that car?
#46
Originally Posted by BetterMakeWay' post='359364' date='Nov 23 2006, 12:28 AM
Or better yet the 535d/335d because the rev range is wider narrower and peak torque sits lower+the higher diesel torque values. That was what i was trying to say.
#47
Not that it was a great car, but the torque curve was completely flat.
#48
My Ride: 535d
Model Year: E61 2006
Originally Posted by skaffa' post='359339' date='Nov 22 2006, 07:16 PM
Why
Skaffa
Skaffa
#49
Originally Posted by Tiago' post='359425' date='Nov 22 2006, 11:37 PM
To avoid transmission vibrations that will wear the transmission quickly
Funny thing is that "big T" does not accelerate car, but it break things. Like volts drives things and amps melt things.
Skaffa
#50
Originally Posted by skaffa' post='360771' date='Nov 26 2006, 04:29 PM
[snip]Funny thing is that "big T" does not accelerate car, but it break things. Like volts drives things and amps melt things.
Skaffa
Skaffa
