E60 530i starts but idrive and all other electronics not working prope
Old 03-22-2011, 09:16 AM
cmunoz323's Avatar
Originally Posted by Anzafin
It could be.
What about the DME (Digital Engine Electronics) unit? One could think that it wouldn't allow the motor to start if it was broken, but it could be the reason .
I'm just wondering why you're not getting any contact with your car via INPA/DIS?
- Antti -
I just spoke to the husband of my girlfriend's friend (A BMW TECH) and he said that it seems like there may be something wrong with the Intelligent Battery Sensor (IBS). That a lot of the times none of the diagnostics software will communicate with the vehicle because the Intelligent Battery Sensor shuts off all the modules. He said that I should try to manually identify my vehicle through DIS and try to diagnose the vehicle that way. He also said I should ensure that the IBS is connected correctly...and...as a last resort...disconnect the battery and connect the positive and negative cables together for about 15 minutes to do a hard reset. I'll keep you guys updated on this issue...I hope this is a learning experience for all of us...
Old 03-22-2011, 09:20 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
What he said makes sense.
Good luck with your efforts!
- Antti -
Old 03-23-2011, 09:23 AM
cmunoz323's Avatar
Ok...I know I'm going to sound like a newbie... but if I need to replace the IBS I have to replace the entire negative terminal battery cable? That cable is discontinued!...
Old 03-23-2011, 09:29 AM
Anzafin's Avatar
Yes you have to replace the whole cable. If you checked it from RealOEM, it may show ENDED or DISCONTINUED, but you should ask your dealer for it. I am sure there is a part available for your car.
- Antti -
Old 09-18-2014, 07:00 PM
FREE100KSECRET's Avatar
My Ride: 545I Sport X5
Model Year: 2007 2003
Engine: 4,4
Curious,
Is there a way to test this battery IBS, it would seem you would just have to make sure you are getting voltage at second terminal, right?
Thanks,
Awest91
09-17-2022 11:05 PM
james69z28
03-23-2015 06:45 PM
ZeZe
10-15-2003 12:58 PM
08-12-2003 11:41 AM
das
06-02-2003 03:55 PM
Quick Reply: E60 530i starts but idrive and all other electronics not working prope
