E60 530d Suspension upgrade advice wanted
Hello.
I'm looking for advice on how to improve the handling of my LCI 530d (non sport). I want to avoid lowering it excessively - less than an inch. Not sure how much that requirement works against the outcome though. My budget is around $1200 (for parts). I will be fitting things myself. Still have the run flats at the moment (Dunlop sport sp 01) but will probably move to normal tyres after they wear out. |
Well not getting much interest here so I'll narrow down the question.
Has anybody fitted a set of sway bars only (no aftermarket springs/shocks) to a std E60? If so what was the ride like afterwards (what was good or bad). Would you recommend this as a first upgrade? I am running 18" wheels on run flats - but will move to std tyres when they wear out. Cheers. |
